I went to go install ROS for my Rassberry Pi and found that there are 5 different variants. What is the difference between them and where can I go to learn about these differences for future updates?
Link to the ROSberryPi downloads I'm talking about: http://wiki.ros.org/ROSberryPi/Setting%20up%20ROS%20on%20RaspberryPi
5
Well this is embarrassing. I didn't realize they are in fact different distributions not variants. Also found the page where you can find out more about them: http://wiki.ros.org/Distributions
  • $\begingroup$ Welcome to Robotics, XavierGuay! No need to be embarrassed - you found the answer to your question! You should be able to (after a day or two, if you can't right now) accept your own answer to your question. $\endgroup$
    – Chuck
    Aug 9 '16 at 12:56
http://wiki.ros.org/ROSberryPi suggests that we should be running ROS Kinetic on all the newer Raspberry Pis since it supports up to Buster with Raspberry Pi 4.
  • $\begingroup$ Welcome to Robotics Stigma. Thanks for your answer but we are looking for comprehensive answers that provide some explanation & context. Very short answers cannot do this, so please edit your answer to explain why it is right. Answers which don't include explanations may be removed. Also, links tend to rot rendering the answer useless if the linked content changes or disappears. Finally, please be nice. For specific guidelines, see our Code of Conduct. $\endgroup$
    – Mark Booth
    Jul 4 '19 at 9:54
