We're use the code underneath to register depth images with color images. With this code a registered depth image keeps the time stamp of its original depth image.
However, since the depth image is now registered with the color image, I'd like the registered depth image to adopt the timestamp of the color image as well. Is there a built-in option to do so? Or do we really need to add a second node to make this happen?
   register_node = ComposableNodeContainer(
        name='container',
        namespace='',
        package='rclcpp_components',
        executable='component_container',
        composable_node_descriptions=[
            ComposableNode(
                package='depth_image_proc',
                plugin='depth_image_proc::RegisterNode',
                name='register_node',
                remappings=[
                    ('depth/image_rect', DEPTH_IMAGE_TOPIC),
                    ('depth/camera_info', DEPTH_CAMERA_INFO_TOPIC),
                    ('rgb/camera_info', COLOR_CAMERA_INFO_TOPIC),
                    ('depth_registered/image_rect', DEPTH_IMAGE_REGISTERED_TOPIC),
                    ('depth_registered/camera_info', DEPTH_CAMERA_INFO_REGISTERED_TOPIC)
                parameters=[
                    {'queue_size': 20}
            ComposableNode(
                plugin='depth_image_proc::PointCloudXyzNode',
                name='point_cloud_xyz_node',
                remappings=[
                    ('camera_info', DEPTH_CAMERA_INFO_REGISTERED_TOPIC),
                    ('image_rect', DEPTH_IMAGE_REGISTERED_TOPIC),
                    ('points', DEPTH_POINTS_TOPIC)
        output='screen',
The timestamp of the data is associated with the time of observation. The default behavior of most elements of processing is to maintain that timestamp through the processing. This is important information to keep the data referenced globally.
If you change the timestamp on the registered point cloud to match the camera image naively by just adjusting the timestamp, if you have moving coordinate frames in your system, you will likely observe that it will no longer be registered exactly the same as the original point cloud in rviz.
To resolve this you need to transform the point cloud to compensate for any potential motion during the delta T. And to compute that motion you need to be able to make an assumption about what coordinate frame the point cloud is static in during that transition. What you'll note is that this is exactly what the tf2 library advanced API provides.
There's not just "built-in option" to do this is that you need more information and context that is often use case specific in it's application.
You haven't explained your use case or motivation. And I would suggest that you consider asking a question about your higher level design and why you're looking to change the timestamp. From what I can read here this sounds like an X-Y problem to me overall.
6
  • $\begingroup$ Hi Tully, thanks for your explanation. Our most important use case is that we register depth images with color images, create a mask from the color images, and then apply that mask to the depth images, to remove irrelevant depth pixels. But there are some more use cases. $\endgroup$ Commented Sep 28, 2023 at 8:01
  • $\begingroup$ First we had ApproximateTimeSynchronizers everywhere we needed matching registered depth images and color images. This makes the pipeline inefficient and harder to debug as the image topics don't show at the same time. $\endgroup$ Commented Sep 28, 2023 at 8:01
  • $\begingroup$ We solved this by introducing a separate node that gives registered depth images the timestamp of the matching color images. But a separate node copies each image. So now we want to avoid copying images for such a simple task. $\endgroup$ Commented Sep 28, 2023 at 8:01
  • $\begingroup$ The point cloud is more a by-product that we can use to visualize depth. However your point of naively changing timestamps still holds (especially for the point cloud then). $\endgroup$ Commented Sep 28, 2023 at 8:01
  • $\begingroup$ Also since there's no built-in solution, I'm considering to add a third nodelet to the ComposableNodeContainer replacing the separate node that we have now. That would save copying images. We just need to make sure not to change the original depth image message, but create a new message with the color image timestamp and the original depth image. $\endgroup$ Commented Sep 28, 2023 at 8:01
