new ROS2/Gazebo user here.
I am trying to implement set up a script for reinforcement learning, currently making a gazebo environment class where upon reset the robot is teleported to a random place upon reset.
Currently I am testing with an empty world where I have added the gazebo_ros_state plugin
<?xml version="1.0" ?>
<sdf version="1.5">
<world name="default">
<plugin name="gazebo_ros_state" filename="libgazebo_ros_state.so">
<ros>
<namespace>/plug</namespace>
<argument>model_states:=model_states_plug</argument>
<argument>link_states:=link_states_plug</argument>
</ros>
<update_rate>1.0</update_rate>
</plugin>
<!-- A global light source -->
<include>
<uri>model://sun</uri>
</include>
<!-- A ground plane -->
<include>
<uri>model://ground_plane</uri>
</include>
</world>
</sdf>
My robot model 'fin_roboclaw" is spawned using spawn_entity.py
And I have a script where my reset function is defined:
import rclpy
from rclpy.node import Node
from rclpy.executors import MultiThreadedExecutor
from gazebo_msgs.msg import EntityState
from gazebo_msgs.srv import SetEntityState
from geometry_msgs.msg import Twist
from nav_msgs.msg import Odometry
from sensor_msgs.msg import LaserScan
from std_srvs.srv import Empty
from visualization_msgs.msg import Marker
class GazeboEnv(Node):
def __init__(self):
super().__init__('env')
self.goal_x = 5.0
self.goal_y = 5.0
self.set_self_state = EntityState()
self.set_self_state.name = 'fin_roboclaw'
self.set_self_state.pose.position.x = 0.0
self.set_self_state.pose.position.y = 0.0
self.set_self_state.pose.position.z = 0.0
self.set_self_state.pose.orientation.x = 0.0
self.set_self_state.pose.orientation.y = 0.0
self.set_self_state.pose.orientation.z = 0.0
self.set_self_state.pose.orientation.w = 1.0
self.set_state = self.create_client(SetEntityState, 'plug/set_entity_state')
self.velocity_publisher = self.create_publisher(Twist, 'cmd_vel', 10)
self.marker_publisher = self.create_publisher(Marker, 'goal_point', 3)
self.reset_proxy = self.create_client(Empty, "/reset_world")
def reset(self):
while not self.reset_proxy.wait_for_service(timeout_sec=1.0):
self.get_logger().info('reset : service not available, waiting again...')
try:
self.reset_proxy.call_async(Empty.Request())
except rclpy.ServiceException as e:
print("/gazebo/reset_simulation service call failed")
x = rng.uniform(1, ENVIRONMENT_X_LEN - 1)
y = rng.uniform(1, ENVIRONMENT_Y_LEN - 1)
while self.check_pos(x, y):
self.goal_x = x
self.goal_y = y
object_state = self.set_self_state
angle = np.random.uniform(-np.pi, np.pi)
quaternion = Quaternion.from_euler(0.0, 0.0, angle)
object_state.pose.position.x = x
object_state.pose.position.y = y
object_state.pose.orientation.x = quaternion.x
object_state.pose.orientation.y = quaternion.y
object_state.pose.orientation.z = quaternion.z
object_state.pose.orientation.w = quaternion.w
while not self.set_state.wait_for_service(timeout_sec=1.0):
self.get_logger().info('set : service not available, waiting again...')
try:
self.set_state.call_async(SetEntityState.Request())
time.sleep(0.2)
Now I know I can teleport my robot outside my script by using this in terminal
ros2 service call /plug/set_entity_state 'gazebo_msgs/SetEntityState' '{state: {name: "fin_roboclaw", pose: {position: {y: 2}}}}'
However I want this handled by the script by calling set_state but I do not know how to populate the SetEntityState with the object_state values. How can I do this?
