I am aiming to achieve smooth robot navigation using the Waypoint Follower action server in the nav2 stack. Specifically, I want the robot to drive around a room close to the walls without slowing down when reaching waypoints.
Here's what I've tried:
Waypoint Follower: I provided the action server with a set of waypoints. Even after using the WaitAtWaipoint plugin with waypoint_pause_duration = 0, the robot still slows down at each waypoint. I observed that a new path calculation occurs every time a waypoint is reached. This makes me think I can't achieve continuous motion with this approach since the path should ideally be calculated before reaching the waypoints.
NavThroughPoses: This didn’t work as expected since in certain scenarios, like narrow corridors, the controller tries to skip waypoints.
Custom Planner Plugin: Implementing this was challenging, especially when creating a path that starts and ends at the same point. For instance, I want the robot to drive around the room without reporting that the destination has been reached, but I had to resort to workarounds to achieve this.
Given these challenges, is there an alternative or suggestion you'd recommend to ensure smooth navigation in this context?
