I am getting a segmentation fault with pcl::transformPointCloud.
This is all I am getting on the terminal:
ros2 run cpp_tests icp_test
initialized
101201
Transforming
[ros2run]: Segmentation fault
My PCL version is 1.12.1.
The line that is causing the error is:
pcl::transformPointCloud(*cloud_in, *cloud_icp, icp_transform);
cloud_in and cloud_icp are both pcl::PointCloud<pcl::PointXYZ>::Ptr, and icp_transform is obtained from PCL and is Eigen::Matrix4f. cloud_in had the input cloud in it, cloud_icp would be empty (it was defined as pcl::PointCloud<pcl::PointXYZ>::Ptr cloud_icp; but not used before this point).
I would like to solve this issue or find a workaround. As far as I can tell, I have only PCL 1.12.1 on my system. I am using ROS2 humble on Ubuntu 22.04. This was compiled using colcon build --symlink-install and compiled without any errors.
Thanks.
With the definition of cloud_icp from your first post, you just declare a pointer of type¹
However, its not pointing to an existing pcl::PointCloud<pcl::PointXYZ> Pointcloud and thus your program crashes when entering the function.
The approach from your own answer
cloud_icp = pcl::PointCloud<pcl::PointXYZ>::Ptr (new pcl::PointCloud<pcl::PointXYZ>(360,1));
creates an underlying Pointcloud.
¹: More precisely, it is a smart pointer of type std::shared_ptr<pcl::PointCloud<pcl::PointXYZ>>.
I found a workaround. Adding
to the constructor solved the problem. I don't know why that helped.
  • $\begingroup$ With the definition of cloud_icp from your first post, you just declare a pointer of type pcl::PointCloud<pcl::PointXYZ> (but its not pointing to an existing pcl::PointCloud<pcl::PointXYZ> Pointcloud and thus your program crashes when entering the function). The approach in your own answer creates an underlying Pointcloud. $\endgroup$
    – Bi0T1N
    Sep 16 at 14:39
  • $\begingroup$ Thank you! Would you be able to add that as an answer? $\endgroup$ Sep 18 at 7:18
  • $\begingroup$ I advise you to read up on c++ a bit; I found Learn C++ a very good resource. $\endgroup$
    – JRTG
    Sep 19 at 14:56
