When point field data is published by the ROS 2 Velodyne LIDAR, it includes a "time" field. I am trying to find out how this field is calculated. Is it:
time = absolute_firing_time - header_stamp.timestamp[0] ?
Also If anyone can share a ros2 bag of velodyne lidar data for my analysis, that would be great too, so I can play it.
These are the lines that handle publishing the Velodyne point cloud data, from the ROS Velodyne driver:
  // publish message using time of last packet read
  ROS_DEBUG("Publishing a full Velodyne scan.");
  if (config_.timestamp_first_packet){
    scan->header.stamp = scan->packets.front().stamp;
  else{
    scan->header.stamp = scan->packets.back().stamp;
  scan->header.frame_id = config_.frame_id;
  output_.publish(scan);
As described there, it's informed by the packet as sent from the Velodyne. I would expect this to be when the distances are read by the sensor not when the emissions are sent: you aren't expected to be doing the time-of-flight math yourself, you just want to know where things are in your environment.
For Non-velodyne LIDARs, I would expect similar behavior. A very common pattern is to read sensor data into a message, then provide a timestamp, then publish.
