I have two launch files: a main launch file, and a sub launch file. The main launch file invokes the sub launch file with
    run_odometry = LaunchConfiguration('run_odometry', default=True)
    sub_launch = GroupAction(
            actions=[
                PushRosNamespace(
                    namespace='some_namespace'
                IncludeLaunchDescription(
                    launch_description_source=PythonLaunchDescriptionSource(
                        launch_file_path=sub_launch_file)
                    launch_arguments=[
                        ('run_odometry', run_odometry)
The sub launch then defines some node parameters:
    default_parameters_file = shared_folder / 'config' / 'default_configs.yaml'
    override_parameters_file = some_folder / 'configs.yaml'
    parameters = [default_parameters_file, override_parameters_file]
and passes those parameters to several nodes, like for instance:
    odometry_node = Node(
        condition=IfCondition(run_odometry),
        package='odometry',
        executable='odometry_node',
        output='screen',
        parameters=parameters
But now I'd like to move parameters from the sub launch file to the main launch file and call the sub launch file with something like:
    parameters = LaunchConfiguration('parameters', default=[default_parameters_file, override_parameters_file])
            actions=[
                PushRosNamespace(
                    namespace="some_namespace"
                    launch_arguments=[
                        ('parameters', parameters),
Then in the sub launch file have something like:
    parameters = LaunchConfiguration('parameters')
and again
        package='visual_odometry',
        executable='visual_odometry_node',
        output='screen',
But that doesn't work: 'Node' expected 'parameters' to be one of [<class 'list'>], but got '<launch.substitutions.launch_configuration.LaunchConfiguration object at 0x7f48e2dd6290>' of type '<class 'launch.substitutions.launch_configuration.LaunchConfiguration'>'
The error makes sense, but I don't know how to make this work. There's hardly any documentation on this. Any ideas? Thanks in advance!
Well I ended up with passing on the launch files as individual launch configs:
    default_parameters_file_config = LaunchConfiguration('default_parameters_file', default=default_parameters_file)
    override_parameters_file_config = LaunchConfiguration('override_parameters_file', default=override_parameters_file)
    run_odometry_config = LaunchConfiguration('run_odometry', default=True)
            actions=[
                PushRosNamespace(
                    launch_arguments=[
                        ("default_parameters_file", default_parameters_file_config),
                        ("override_parameters_file", override_parameters_file_config),
                        ("run_odometry", run_odometry_config)
I would have liked a more flexible solution allowing any amount of parameter files, but that became too messy and this serves my purposes too.
Perhaps you can try with evaluation of the parameters with OpaqueFunction (example here: [1]) in the sub launch file to get these parameters to set them in the higher level launch file the usual way.
  • $\begingroup$ Thanks for your suggestion. I ended up with the solution I wrote above. It's not exactly what I wanted, but it's clean and easy to read. $\endgroup$ Commented Sep 19, 2023 at 12:25
