I am trying to install ROS2 "Humble Hawksbill" on Windows 10, but when done and trying to run ros2 I get the error:
failed to create process.
I get the same result when activating the ROS environment first with local_setup.
I followed the instructions here: https://docs.ros.org/en/humble/Installation/Windows-Install-Binary.html#install-python
The only difference is I have Python 3.8.10. Other system info:
> systeminfo.exe
Host Name:                 xxxx
OS Name:                   Microsoft Windows 10 Pro
OS Version:                10.0.19045 N/A Build 19045
OS Manufacturer:           Microsoft Corporation
OS Configuration:          Member Workstation
OS Build Type:             Multiprocessor Free
Registered Owner:          sa-install
Registered Organization:   Demcon
Product ID:                00330-80000-00000-AA932
Original Install Date:     15-4-2022, 05:14:30
System Boot Time:          12-9-2023, 10:41:29
System Manufacturer:       HP
System Model:              HP ZBook Fury 15.6 inch G8 Mobile Workstation PC
System Type:               x64-based PC
Processor(s):              1 Processor(s) Installed.
                           [01]: Intel64 Family 6 Model 141 Stepping 1 GenuineIntel ~2304 Mhz
BIOS Version:              HP T95 Ver. 01.08.20, 14-3-2022
Windows Directory:         C:\windows
System Directory:          C:\windows\system32
Boot Device:               \Device\HarddiskVolume1
System Locale:             en-gb;English (United Kingdom)
Input Locale:              en-us;English (United States)
Time Zone:                 (UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna
Total Physical Memory:     16'048 MB
Available Physical Memory: 6'033 MB
Virtual Memory: Max Size:  28'336 MB
Virtual Memory: Available: 11'376 MB
Virtual Memory: In Use:    16'960 MB
Page File Location(s):     C:\pagefile.sys
Domain:                    xxxx
Logon Server:              xxxx
Hotfix(s):                 20 Hotfix(s) Installed.
There are some similar questions already, but their accepted answers did not help me:
EDIT: I just realized that calling ROS2 from Python does work:
> python Scripts\ros2-script.py
usage: ros2 ...
But running the .exe gives the error:
> ros2.exe
I think I more or less solved it. I redid my steps in Windows Sandbox, to test from a fresh system, and I found the following:
  1. Download ROS2 binaries without anything else. Unpacked into C:\dev\ros2_humble
    • Running Scripts\ros2.exe now gives my infamous error "failed to create process."
    • local_setup.ps1 now fails of course, as no Python is available.
  2. Install Python 3.8.3 with default settings, under C:\Program Files\Python38, without adding to path (to mimic my PC with multiple Python versions).
    • Same results in the previous step.
    • Running & "C:\Program Files\Python38\python.exe" Scripts\ros2-script.py gives errors about missing packages (of course).
  3. Install requirements: & "C:\Program Files\Python38\python.exe -m pip install ...
    • & "C:\Program Files\Python38\python.exe" Scripts\ros2-script.py now seems to work fine, without errors!
    • ros2.exe still gives "failed to create process.". But that I could understand, Python isn't available yet.
  4. Add system Python to PATH
    • python Scripts\ros2-script.py now also works
    • ros2.exe still fails with the same error
Then either:
  1. Create a symbolic link: mklink /D "C:\Python38" "C:\Program Files\Python38"
    • Running ros2.exe now actually works! It seems it really relies on the hardcoded Python path.
or
  1. Edit Scripts\ros2-script.py and replace the hash-bang path at the top C:\Python38\python.exe with C:\Program Files\Python38\python.exe
    • Running ros2.exe now also works! I had no idea the .exe was actually relying on the hash-bang path.
Finally I wanted to test with Python virtual environments. I rolled back to step #2 (with only Ros2 unpacked and a fresh Python install).
  1. Create venv, in C:\dev\ros2_humble\: & "C:\Program Files\Python38\python.exe" -m venv .venv
  2. Activate it: .\venv\Scripts\activate.ps1
  3. Check it and prepare it: python --version and python -m pip install ...
  4. Now also activate the ros2 environment: local_setup.ps1
    • python Scripts\ros2-script.py now works!
    • But ros2.exe still fails... It depends on the fixed paths.
  5. Edit *-script.py such that the line 1 path says #!C:\dev\ros2_humble\.venv\Scripts\python.exe
    • And now finally ros2.exe just works, from an isolated environment!
So in a nutshell:
  • The hash-bang path from *-script.py must match with the intended Python executable
  • local_setup.ps1 but be active, i.e. PYTHONPATH must include the site-packages from ros2 and the interpreter library path (either system or a venv)
And the error
was entirely due to the script hash-bang not being available.
  • $\begingroup$ Thanks for the follow-up. Python and Windows tend to be a bit brittle. Is this something that we could also adjust in the upstream to make it better? $\endgroup$
    – mjcarroll
    Sep 13 at 12:59
    $\begingroup$ I would say ideally only a global python is used, without any absolute paths at all. How are the .exe files made? Could they be built without full path mentions of Python? $\endgroup$
    – Roberto
    Sep 14 at 7:08
