I am a third-year electrical engineering student and am working on an intelligent autonomous robot in my summer vacations.
The robot I am trying to make is supposed to be used in rescue operations. The information I would know is the position of the person (the coordinates of the person in a JSON file that can be changed anytime except during the challenge) to be rescued from a building on fire. I would also know the rooms of the building from a map, but I don't know where the robot may be placed inside the building to start the rescue operation.
That means I have to localise the robot placed at an unknown position in a known environment, and then the robot can plan its path to the person who has to be rescued. I can use gyroscope, accelerometer, magnetometer and ultrasonic sensors to do the localising job. I cannot use a GPS module or a camera for this purpose.
The object to be rescued (whose location is known in terms of coordinates & can be changed anytime) is surrounded by walls from 3 sides. Hence, adding more walls in this map.
According to my research particle filter is the best method used for localization of robot. But how can I deal with the landmarks (walls) that are fixed as shown in the map image and that are variable depending on the location of the object to be rescued being provided in the JSON file?
I can do the path planning from a known position to the target position, but I'm not sure how to determine the starting position.
More about JSON file: (1) json file containing the coordinates of the object to be rescued can change. (2) it won't change during the challenge. (3) json file will be provided to me in an SD card that my robot has to read. I have successfully written the code that will allow the robot to read the json file and hence the coordinates of the object to be rescued.
Here is the map of the building which is known to me.
