I'm having troubles with model origin of coordinates location in relation to STL models. All ones are outside the models. I tried to move it to center of mass in SolidWorks, but it didn't fix the problem. It causes different issues like my wheels spin around origin of coordinates, not around own axis.
It's my wheel xacro:
<?xml version="1.0" encoding="utf-8"?>
<robot name="pushkin"
xmlns:xacro="http://www.ros.org/wiki/xacro">
<!-- right_wheel -->
<link name="pushkin_right_wheel">
<inertial>
<!-- <origin xyz="1.9255E-10 -0.00056576 1.0414E-10" rpy="0 0 0"/> -->
<origin xyz="0 0 0" rpy="0 0 0"/>
<mass value="0.050464"/>
<inertia ixx="2.0701E-05" ixy="3.8089E-14" ixz="-1.3584E-15" iyy="3.5827E-05" iyz="2.1838E-15" izz="2.0701E-05"/>
</inertial>
<visual>
<origin xyz="0 0 0" rpy="0 0 0" />
<geometry>
<mesh filename="package://pushkin_description/meshes/pushkin_right_wheel.STL" scale="0.01 0.01 0.01" />
</geometry>
<material name="Green" />
</visual>
<collision>
<geometry>
</geometry>
</collision>
</link>
<joint name="right_wheel_to_base" type="continuous">
<origin xyz="0.11 0.5137 -0.135" rpy="0 0 0" />
<parent link="pushkin_base" />
<child link="pushkin_right_wheel" />
<axis xyz="0 1 0" />
</joint>
</robot>
