I am using the ROS2 Humble Navigation2 package and want to check if the robot reached the goal position (or it reached the xy_goal_tolerance zone).
I know there is a GoalStatus message in ROS2 foxy but I cannot find its corresponding version in ROS2 humble.
Is there a way to use a similar message in Ros2 humble?
Thanks in advance!
Its all the same for all ROS 2 distributions.
You should be able to see it with
$ cat /opt/ros/humble/share/action_msgs/msg/GoalStatus.msg
New contributor
alek is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
