New to this forum and ROS.
I have two machines running Ubuntu on WSL2. I have installed ROS2 humble on both ubuntuWSL machines. The two machines are connected via local network so pinging them is not a problem. However, the WSL instances sit behind a virtual ethernet with IP address on different subnets. Here is the configuration of IPs on both machines:
Machine-1: Windows IP: 192.168.43.10 WSL IP: 172.26.177.47
Machine-2: Windows IP: 192.168.43.23 WSL IP: 172.26.1.66
So the ubuntu WSL on machine-1 cannot discover the ubuntu WLS on machine-2. I have tried port forwarding but still same issue. My understanding is that the ROS node on machine-1 inside the WSL cannot discover the other node on machine-2 (inside the WSL) because they are not different nets.
