I want to deserialize messages from a Bag file and publishing part of their contents with ROS for further processing.
I read a bagfile with the ROS C++ API. I know exactly the content (topic names and types) of my messages at compile time, such that I want to deserialize it into common ROS defined classes (e.g. the ones defined here https://docs.ros.org/en/noetic/api/sensor_msgs/html/index-msg.html) at runtime. Here some code:
#include <rosbag/bag.h>
#include <rosbag/view.h>
//other content
  rosbag::Bag bag;
  bag.open("foo.bag", rosbag::bagmode::Read);
  std::vector<std::string> topics{"camera1/camera_info"};
  rosbag::View view(bag, rosbag::TopicQuery(topics));
  for(auto const m : view)
      const std::string& topic_name = m.getTopic();
      std::cout << topic_name << std::endl;
      std_msgs::String::ConstPtr s = m.instantiate<std_msgs::String>();
      if (s != NULL)
          std::cout << s->data << std::endl;
      // I want the data in s as a string to be serialized into an instance
      // of the type CameraInfo located in
      // path/ros/distro/sensor_msgs/CameraInfo.h shipping with ROS.
      CameraInfo ci = is_there_any_os_solution(s); //?
  bag.close();
I tried to find something on this direction but I just found libraries deserializing contents unknown at compile time.
Could anyone give some hints?
I think that you're looking for the instantiate method on the rosbag MessageInstance
There's a very minimal example here
BOOST_FOREACH(rosbag::MessageInstance const m, view)
    std_msgs::Int32::ConstPtr i = m.instantiate<std_msgs::Int32>();
And more examples here and a cookbook of examples using the rosbag API.
  • $\begingroup$ Thanks! I do not know how safe this is but I tried with more complex types like CameraInfo in sensor_msgs and it really works! I thought this was only working with primitive types but how wrong I was. $\endgroup$
    – tricostume
    Commented Sep 8, 2023 at 17:04
