I am trying to use a web cam with the aruco_ros
package to estimate the pose of an ArUco marker. The package I am using to get the camera images is the v4l2_camera
package but I am having a problem, v4l2_camera_node
is publishing /camera_info
without the information like this:
header:
stamp:
sec: 1694104949
nanosec: 776459841
frame_id: ''
height: 480
width: 640
distortion_model: ''
d: []
k:
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
r:
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
p:
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
binning_x: 0
binning_y: 0
roi:
x_offset: 0
y_offset: 0
height: 0
width: 0
do_rectify: false
I already calibrated my camera with the camera_calibration
package and saved the results. When I run v4l2_camera_node
I get a couple errors:
[INFO] [1694106573.030815912] [v4l2_camera]: Driver: uvcvideo
[INFO] [1694106573.031204681] [v4l2_camera]: Version: 393743
[INFO] [1694106573.031261676] [v4l2_camera]: Device: Integrated Camera: Integrated C
[INFO] [1694106573.031301723] [v4l2_camera]: Location: usb-0000:00:14.0-8
[INFO] [1694106573.031338402] [v4l2_camera]: Capabilities:
[INFO] [1694106573.031374606] [v4l2_camera]: Read/write: NO
[INFO] [1694106573.031411856] [v4l2_camera]: Streaming: YES
[INFO] [1694106573.031454594] [v4l2_camera]: Current pixel format: YUYV @ 640x480
[INFO] [1694106573.031619333] [v4l2_camera]: Available pixel formats:
[INFO] [1694106573.031663159] [v4l2_camera]: MJPG - Motion-JPEG
[INFO] [1694106573.031699589] [v4l2_camera]: YUYV - YUYV 4:2:2
[INFO] [1694106573.031733434] [v4l2_camera]: Available controls:
[INFO] [1694106573.031775698] [v4l2_camera]: Brightness (1) = 128
[INFO] [1694106573.031820045] [v4l2_camera]: Contrast (1) = 32
[INFO] [1694106573.031860894] [v4l2_camera]: Saturation (1) = 64
[INFO] [1694106573.032499536] [v4l2_camera]: Hue (1) = 0
[INFO] [1694106573.032556092] [v4l2_camera]: White Balance, Automatic (2) = 1
[INFO] [1694106573.032598837] [v4l2_camera]: Gamma (1) = 120
[INFO] [1694106573.032640281] [v4l2_camera]: Power Line Frequency (3) = 1
[INFO] [1694106573.033182735] [v4l2_camera]: White Balance Temperature (1) = 4600 [inactive]
[INFO] [1694106573.033259586] [v4l2_camera]: Sharpness (1) = 0
[INFO] [1694106573.033303499] [v4l2_camera]: Backlight Compensation (1) = 1
[ERROR] [1694106573.033357630] [v4l2_camera]: Failed getting value for control 10092545: Permission denied (13); returning 0!
[INFO] [1694106573.033395094] [v4l2_camera]: Camera Controls (6) = 0
[INFO] [1694106573.033426300] [v4l2_camera]: Auto Exposure (3) = 3
[INFO] [1694106573.033979184] [v4l2_camera]: Exposure Time, Absolute (1) = 156 [inactive]
[INFO] [1694106573.034107672] [v4l2_camera]: Exposure, Dynamic Framerate (2) = 0
[WARN] [1694106573.035972783] [v4l2_camera]: Control type not currently supported: 6, for control: Camera Controls
[INFO] [1694106573.037698539] [v4l2_camera]: Starting camera
[WARN] [1694106573.248302454] [v4l2_camera]: Image encoding not the same as requested output, performing possibly slow conversion: yuv422_yuy2 => rgb8
[INFO] [1694106573.254334950] [v4l2_camera]: using default calibration URL
[INFO] [1694106573.254442777] [v4l2_camera]: camera calibration URL: file:///home/automatebase/.ros/camera_info/integrated_camera:_integrated_c.yaml
[ERROR] [1694106573.254593077] [camera_calibration_parsers]: Unable to open camera calibration file [/home/automatebase/.ros/camera_info/integrated_camera:_integrated_c.yaml]
[WARN] [1694106573.254640735] [v4l2_camera]: Camera calibration file /home/automatebase/.ros/camera_info/integrated_camera:_integrated_c.yaml not found
There is no /camera_info folder inside /.ros, shoud I just create that folder and paste the the YAML file from the calibration?
[EDIT] Using usb_cam
package:
I also tried using the usb_cam
package instead of the v4l2_camera
package, however I have the same problem, the usb_camera_node
gives me the error:
[ERROR] [1694444697.653173284] [usb_cam]: Invalid camera calibration URL: /home/automatebase/.ros/camera_info/camera_info.yaml
And the camera info is not published. This is the output from the calibration node in case that helps:
mono pinhole calibration...
D = [0.14880426526992593, -0.03236985997669252, -0.01781091717583487, 0.0236618003681507, 0.0]
K = [674.5058161190959, 0.0, 346.95961390137086, 0.0, 675.1512129728582, 198.31744172459904, 0.0, 0.0, 1.0]
R = [1.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 1.0]
P = [702.38525390625, 0.0, 355.45461080182577, 0.0, 0.0, 709.22509765625, 193.2878561560501, 0.0, 0.0, 0.0, 1.0, 0.0]
None
# oST version 5.0 parameters
[image]
width
640
height
480
[camera]
camera matrix
674.505816 0.000000 346.959614
0.000000 675.151213 198.317442
0.000000 0.000000 1.000000
distortion
0.148804 -0.032370 -0.017811 0.023662 0.000000
rectification
1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
projection
702.385254 0.000000 355.454611 0.000000
0.000000 709.225098 193.287856 0.000000
0.000000 0.000000 1.000000 0.000000
('Wrote calibration data to', '/tmp/calibrationdata.tar.gz')
[image]
width
640
height
480
[camera]
camera matrix
distortion
rectification
projection
Not available
