I am running ROS2 Humble on my Raspberry Pi 3 and I also have a Raspberry Pi Pico running micro ROS. I am trying to install the micro ROS agent on my RPi3. The snap version of the micro ROS agent did not work due to no stable release for arm. I tried building the micro ROS agent from: https://github.com/micro-ROS/micro_ros_setup#building-micro-ros-agent
The process is stuck on [1/2 completed] for over 2 hours. Is this normal or is something wrong? How can I fix this or install a pre-built version of micro ROS agent on the RPi3.
