I am trying to fly a tello drone in a gazebo simulation ROS Driver for the tello Drone. When I try running the following script, (after ofcourse building the package) -
#!/usr/bin/env python3
import rclpy
from rclpy.node import Node
from geometry_msgs.msg import Twist
class DroneSim(Node):
    def __init__(self):
        super().__init__('velocity_publisher_node')
        self.publisher_ = self.create_publisher(Twist, '/drone1/cmd_vel', 10)
        timer_period = 0.5  # seconds
        self.timer = self.create_timer(timer_period, self.timer_callback)
        self.i = 0
    def timer_callback(self):
        twist = Twist()
        twist.linear.x = 1.0
        twist.angular.z = 1.0
        # add code to check if drone has taken off and only then publish velocity
        self.publisher_.publish(twist)
        self.get_logger().info(f'Publishing: {twist.linear.x}, {twist.angular.z}')
        self.i += 1
def main(args=None):
    rclpy.init(args=args)
    drone_sim = DroneSim()
    rclpy.spin(drone_sim)
    # Destroy the node explicitly
    # (optional - otherwise it will be done automatically
    # when the garbage collector destroys the node object)
    drone_sim.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
I use the following command to run the script -
ros2 run drone_sim test.py
I face the following error -
/opt/ros/foxy/bin/ros2:6: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html
from pkg_resources import load_entry_point
No executable found
I have tried upgrading, uninstalling and installing setuptools package, and numerous other things but it still does not seem to work.
I am on Ubunutu 20.04 and running ROS2 Foxy. The package is an ament_cmake package.
Thanks!
Downgrade setuptools when you are using ROS2 foxy. Which is a known issue (mentioned here in the ROS 2 repository) :)
pip3 install setuptools==58.2.0
  • $\begingroup$ Hey, thanks for the reply but I was able to get this running successfully. I honestly don't remember how as I didn't document it at the time. Thabk you so much for the help. Hopefully this is helpful to someone. $\endgroup$ Dec 12, 2023 at 10:04
