What I'm currently doing is I'm trying to replace Gazebo 11 with Gazebo garden in this document. However, I ran into a problem when learning robot_localization.
First, I try to set ekf_filter_node as follows. And only read odometry information. In my understanding this could generate the conversion of odom to base_link (should be published to /tf). However, it didn't happen.
ekf_filter_node:
    ros__parameters:
        frequency: 30.0
    two_d_mode: false
    publish_acceleration: false
    publish_tf: true
    map_frame: map              # Defaults to "map" if unspecified
    odom_frame: odom            # Defaults to "odom" if unspecified
    base_link_frame: base_link  # Defaults to "base_link" ifunspecified
    world_frame: odom           # Defaults to the value ofodom_frame if unspecified
    odom0: demo/odom
    odom0_config: [true,  true,  true,
                   false, false, false,
                   false, false, true,
                   false, false, false]
    # imu0: demo/imu
    # imu0_config: [false, false, false,
    #               true,  true,  true,
    #               false, false, false,
    #               false, false, false]
The following is the header information of /demo/odom
header:
    stamp:
        sec: 48
        nanosec: 600000000
    frame_id: odom
child_frame_id: base_link
The following is tf tree enter image description here
I think there should be an arrow pointing to base_link from odom in the picture. Is this understanding wrong?
Second, regarding the settings of IMU sensor data.The following sentence from the documentation
This offset is typically specified by a static transform from the base_link_frame parameter to the IMU message’s frame_id.
My understanding is that the ekf_node of robot_localization will read the frame_id in the imu sensor (in this example, it comes from /demo/imu) and convert the coordinate system to base_link according to the conversion in the tf tree. However, the frame_id in the data sent from Gazebo garden (Gazebosim) is as follows
header:
    stamp:
        sec: 1279
        nanosec: 760000000
frame_id: sam_bot/base_link/imu_sensor
The tf tree diagram is as above, and imu is located above imu_link. Does this mean I need to change the frame_id in the imu message to imu_link?
Thank you for reading my question.
Regarding the first question, I later found that in the launch file, I set use_sim_time=true, which made ekf_node try to subscribe to the /clock topic, so it is necessary to convert Gazebo’s /clock topic to the ros2 topic through the ros_gz_bridge package so that it can receive Time message. This also means that the time data of the sensor must match the time data of the ekf_node.
For the second question, I added an additional branch on tf_tree through tf2 static broadcast so that ekf_node can correctly find the corresponding frame.
