I've done the tutorial for tf2, and everything works fine. Now I'm trying to reproduce the "follow" behavior with drones, but this time it fails. I've got a Node for each drone. I do the broadcast exactly like in the tutorial and it works. At least I can see the transformation with ros2 run tf2_ros tf2_echo cis_drone_2 cis_drone_1
At time 1693834924.724220138
- Translation: [1.000, 1.000, 0.000]
- Rotation: in Quaternion [0.000, -0.000, -0.000, 1.000]
- Rotation: in RPY (radian) [0.000, -0.000, -0.000]
- Rotation: in RPY (degree) [0.000, -0.000, -0.000]
- Matrix:
  1.000  0.000 -0.000  1.000
 -0.000  1.000 -0.000  1.000
  0.000  0.000  1.000  0.000
  0.000  0.000  0.000  1.000
This is on startup, both drones are on the floor. Then I start the "follow action" building the TransformListener once again like in the tutorial. Here is my callback
# frames involved
from_frame = self._leader
to_frame = self.name
# Look up for the transformation between leader_frame and this mobile frame
try:
    t = self.__buffer.lookup_transform(
        to_frame,
        from_frame,
        rclpy.time.Time(),
        timeout=rclpy.duration.Duration(seconds=3.0),
except TransformException as ex:
    self.get_logger().info(
        f'Could not transform {to_frame} to {from_frame}: {ex}')
    return
self.get_logger().info(f"Transform is {t}")
Here I get an exception :
Could not transform cis_drone_2 to cis_drone_1: "cis_drone_2" passed to lookupTransform argument target_frame does not exist.
And in the terminal running tf2_echo I get this error :
Failure at 1693834935.374
Exception thrown:Lookup would require extrapolation into the past.  Requested time 1693834924.724220 but the earliest data is at time 1693834925.739769, when looking up transform from frame [cis_drone_1] to frame [cis_drone_2]
The current list of frames is:
Frame cis_drone_1 exists with parent warehouse_lanes.
Frame cis_drone_2 exists with parent warehouse_lanes.
I tried to use 0 as a value for time in lookup_transform, doc says it will get the latest, but I get this new error
[drone-11]   File "/opt/ros/humble/lib/python3.10/site-packages/tf2_ros/buffer.py", line 135, in lookup_transform
[drone-11]     self.can_transform(target_frame, source_frame, time, timeout)
[drone-11]   File "/opt/ros/humble/lib/python3.10/site-packages/tf2_ros/buffer.py", line 221, in can_transform
[drone-11]     not self.can_transform_core(target_frame, source_frame, time)[0] and
[drone-11] TypeError: time must have sec and nanosec, or nanoseconds.
Do I have to use the "traveling in time" to perform this "immediate" follow ?
  • $\begingroup$ After playing with parameters, I found that timeout has to be as small as possible to avoid my problem. So my best solution is to simply do not set it which makes it to Duration() which is probably equal to 0 s. Still I do not understand why it is necessary. $\endgroup$
    – SebL
    Sep 5 at 9:35
