I am trying to spawn custom urdf in ros2. I have following launch file
import os
from ament_index_python.packages import get_package_share_directory
from launch.actions import DeclareLaunchArgument, ExecuteProcess
from launch.substitutions import LaunchConfiguration
from launch_ros.actions import Node
    use_sim_time = LaunchConfiguration('use_sim_time')
    # urdf_file_name = 'urdf/AMR.urdf'  # Relative path from the package
    # print("urdf_file_name : {}".format(urdf_file_name))
    urdf = os.path.join(
        get_package_share_directory('amr_robot'),
        urdf_file_name)
    return LaunchDescription([
        DeclareLaunchArgument(
            'use_sim_time',
            default_value='true',
            description='Use simulation (Gazebo) clock if true'),
        ExecuteProcess(
            cmd=['gazebo', '--verbose', '-s', 'libgazebo_ros_factory.so'],
            output='screen'),
        Node(
            package='gazebo_ros',
            executable='spawn_entity.py',
            name='urdf_spawner',
            output='screen',
            arguments=[
                "-topic", "/robot_description",
                "-entity", "AMR",
                "-robot_namespace", "/"  # Optional, set if necessary
when I launch it only gazebo open and robot does not spawn
    $\begingroup$ Welcome to Robotics Stack Exchange! The robot can not be instantiated because there is no robot_description $\endgroup$
    – ravi
    Commented Sep 3, 2023 at 7:53
  • $\begingroup$ can you kindly fix it and give the correct launch file in answer section. Thank you $\endgroup$
    – Mubashir
    Commented Sep 3, 2023 at 7:54
The robot_state_publisher node is missing in the launch file. The spawn_entity.py node is waiting for a urdf string in the topic robot_description. But since robot_state_publisher is not included, there is no node publishing to that topic. Refer to this link for syntax/examples.
