I am trying to build ROS Noetic on Ubuntu 23.04 and python 3.11.4 from source. Referring to the offical ROS documentation.
Step 1: Installing bootstrap dependencies:
$ sudo apt-get install python3-rosdep python3-rosinstall-generator python3-vcstools python3-vcstool build-essential
Gives the error:
E: Unable to locate package python3-rosdep
E: Unable to locate package python3-vcstool
Step 2: For this, the documentation asks to add the packages.ros.org debian repository to apt source lists: click here:
sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list'
I tried the above step and it was executed without producing any error.
But, I am still getting the same error when I tried Step 1 after Step 2 again.
Also, after step 2 when I run:
sudo apt update
It says:
Hit:1 http://us.archive.ubuntu.com/ubuntu lunar InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu lunar-updates InRelease
Hit:3 http://security.ubuntu.com/ubuntu lunar-security InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu lunar-backports InRelease
Ign:5 http://packages.ros.org/ros/ubuntu lunar InRelease
Hit:6 https://mirror.mwt.me/shiftkey-desktop/deb any InRelease
Err:7 http://packages.ros.org/ros/ubuntu lunar Release
404  Not Found [IP: 2605:bc80:3010::134 80]
Get:8 https://download.opensuse.org/repositories/home:/npreining:/debian-ubuntu-
onedrive/xUbuntu_22.04./InRelease [1,604 B]
Reading package lists... Done
E: The repository 'http://packages.ros.org/ros/ubuntu lunar Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
When I visited to ROS packages repository, I couldn't see the the folder for Ubuntu 23.04 (lunar), does it mean that there is no package available yet for Ubuntu 23.04?
I haven't installed ROS from source before, any help is highly appreciated.
    $\begingroup$ Welcome to Robotics Stack Exchange! I suggest installing from the source, as you mentioned, and then reporting the errors/issues here. In that way, once we know the problem, it would be easy to find a solution. Thanks for your kind cooperation. $\endgroup$
    – ravi
    Commented Aug 16, 2023 at 2:00
  • $\begingroup$ Please move all your comments to the question and modify your query including the title accordingly. Take a look at How to Ask and tour for more information on how stack exchange works, and the Robotics question checklist for details of how to write a good question. $\endgroup$
    – ravi
    Commented Aug 25, 2023 at 1:52
  • $\begingroup$ Thanks for the suggestions! $\endgroup$ Commented Aug 25, 2023 at 3:40
  • $\begingroup$ There aren't any pre-built noetic packages for 23.04 on packages.ros.org, I don't think any of those 'Ubuntu install of ROS Noetic' instructions are what you want- what happens if you undo that change to /etc/apt/sources.list.d/ros-latest.list, run apt update, and follow just the 'Installing from source' instructions? $\endgroup$ Commented Aug 25, 2023 at 20:22
For these two packages, please install the following ones:
sudo apt install python3-rosdep2
sudo apt install python3-vcstools
I just tried it on Ubuntu 23.04 (Lunar) and found them working!
  • $\begingroup$ Thanks for the answer, I tried it but faced the same error, can you see my updated question. $\endgroup$ Commented Aug 25, 2023 at 19:35
  • $\begingroup$ As I said, both of the above packages are tested on Ubuntu 23.04 (Lunar) and found working. Surprisingly, in your updated question, you are still installing old packages such as python3-rosdep and python3-vcstool. BTW, I found following links that could assist and provide some ideas for ROS Noetic in Ubuntu 23.04: 1, 2, and 3 $\endgroup$
    – ravi
    Commented Aug 27, 2023 at 5:35
As it is stated here, ROS Noetic is officially only targeting Ubuntu 20.04.
I never build ROS Noetic from sources on ubuntu 23.04, but recently I build it on Ubuntu 22.04. All the necessary steps are documented at the following blog post Building ROS Noetic on Ubuntu 22.04.
Maybe this helps!
