I am recording data from a range scanner with ROS Melodic using the following command:
rosbag record -o nav310_ws/bagFiles/session --split --duration=1 --max-splits 1 /cloud
In the bagFiles folder, only the latest bag files are kept. So I was wondering how to copy all recorded bag files and save them to another folder. I tried the following command just after the first one, but it did do anything.
cp -a nav310_ws/bagFiles/. nav310_ws/allBags/
Thank you for any suggestion you could provide.
Originally posted by Ben Brian on ROS Answers with karma: 3 on 2023-07-06
If you want to keep the older bag files, you should not be using the --max-splits 1 option. The command:
rosbag record --help
explains what the options do.
Originally posted by Mike Scheutzow with karma: 4903 on 2023-07-09
