Hi everyone! I'm trying to understand the best way to setup my environment for ROS2+Gazebo.
Up until now I was using an Ubuntu 22.04 VM with Virtualbox to get simple exercises up and running in ROS2, with no major problem. Since I have to go up a step and start a more complex system, plus I'll need Gazebo for simulations, I thought about how to improve the environment, given that there is always some kind of performance issue using VMs. It seems my options are:
  • dual boot
  • Docker
  • Git Bash from CMD, as if I was actually on Unix
Since for simplicity of use, budget (can't get another laptop) and resources (my laptop's SDD is not that big) the dual boot is not an option, I moved to Docker. I set up the container (osrf/ros), I installed XLaunch for the GUI and successfully integrated Docker with WSL2. Everything following this guide
However, I can't seem to use my Nvidia graphic card. I've tried launching the turtlesim node + teleop, but it's laggy and slow and Task Manager does not show the process as executing with the Nvidia card.
Has anyone managed to successfully setup a similar environment? Or is there any other option that is actually better than this?
Thanks in advance!
Originally posted by slim71 on ROS Answers with karma: 18 on 2023-04-22
To anybody interested, I gave up.
Getting everything set up on Windows is such a pain, and gives no benefits.
I've found a SSD drive empty and setup a detachable dual-boot with Ubuntu there.
Originally posted by slim71 with karma: 18 on 2023-05-20
