Hi,
I am transferring my robot hardware interface to ROS2. In my ROS1 hardware interface, I used a publisher to publish additional information like the current controller temperature, limit switches status etc. However, in ROS2, I could not find a way to access the node from the hardware interface plugin, so creating a publisher is not possible anymore.
Is it possible to get access to the node in a hardware interface plugin? Or, if not, what is the preferred way to communicating additional hardware state information in ROS2?
Thanks!
Originally posted by rick95 on ROS Answers with karma: 3 on 2023-04-04
Afaik, "nothing has changed" wrt the best / accepted practices in ros2_control vs ros_control. See #q375296 for a previous Q&A which discussed a similar topic (related: ros-controls/ros2_control#740, although that issue asks whether using pub-sub for interaction with the actual hw would be acceptable/ok -- it links to the ROS Answers Q&A though).
Summarising: the cleanest way to publish the kinds of information you mention would be from ros2_control broadcasters (used to be called controllers, but they only published information, so the name was (finally) changed).
You could take a look at UniversalRobots/Universal_Robots_ROS2_Driver which follows that recommendation for things like GPIO and some other status information.
Originally posted by gvdhoorn with karma: 86574 on 2023-04-05
Comment by rick95 on 2023-04-05:
Thanks for your answer! So, if I understand it right, I need to add additional state interfaces (hardware_interface::StateInterface) for the additional state information. Then the joint_state_broadcaster publishes the additional state information on a topic.
Comment by gvdhoorn on 2023-04-05:
Almost.
You'd add your own custom hardware interfaces, for which you then would need to implement your own custom broadcasters.
The default joint_state_broadcaster would only "know" how to publish JointState messages. It can't do anything with your custom state information.
for limit switches specifically, you might be able to reuse the GPIO infrastructure in ros2_control. That is, if you don't necessarily need any higher level semantics for that (ie: instead of "pin 3 is high", you'd want "limit switch of motor/joint 'elbow' is high").
