Hi! We are using ROS1 Noetic on Ubuntu 20.04 with regular desktop version.
We have some processes using internet, for example,
  • streaming some topics content to a commercial cloud server,
  • Ntrip RTK for gps correction.
Now we want to monitor the bandwidth and data usage, so in Ubuntu System Monitor, there's a section "Network History" contains Total Received and Total Sent.
So our question is, Does this total received/sent value include only those interaction with Internet, like the 2 processes mentioned above? Or does this total value also include the data flow within ROS, like node publish/subscribe: node_A -> topic_1 -> node_B?
We have very limited knowledge of network. If System Monitor is not the right tool, is there a better tool to monitor the data usage?
Thank you!
Originally posted by Mingjie on ROS Answers with karma: 26 on 2023-01-12
Comment by Davies Ogunsina on 2023-01-12:
Try using :
htop
Comment by Mingjie on 2023-01-16:
I did a simple test for my question about System Monitor: I found that it does not include the publish/subscribe.
One possible solution: Using psutil package in python, you can monitor individual ports/adapters for traffic, so if you want to monitor just the port to your internet router that is simple.
To answer your direct question about System Monitor, wouldn't it be simple to test this by getting data with and without that access to internet active?
Originally posted by billy with karma: 1850 on 2023-01-13
You can use the command line tool rostopic bw to check the bandwidth used by a certain topic. Documentation
