 #!/usr/bin/env python3
import rclyp
from rclyp.node import Node
def main(args = None):
    rclyp.init(args = args)
    node = Node("py_test")
    node.get_logger().info("Hello ROS2")
    rclyp.shutdown()
if __name__ == "__main__":
    main()
Hi I am new at ROS2 trying to use this code but my terminal says :
> user@user-VirtualBox:~/ros2_ws/src/my_py_pkg/my_py_pkg$
> ./my_first_node.py  Traceback (most
> recent call last):   File
> "/home/user/ros2_ws/src/my_py_pkg/my_py_pkg/./my_first_node.py", line 3, in <module>
>     import rclyp ModuleNotFoundError: No module named 'rclyp'
I have tried this link but It doesn't look like same error like I got.
Originally posted by fkaan on ROS Answers with karma: 1 on 2022-12-20
The name of the Python client library for ROS 2 is rclpy.
You have:
import rclyp
you'll have to update all references to rclyp and replace them by rclpy.
Originally posted by gvdhoorn with karma: 86574 on 2022-12-20
Comment by fkaan on 2022-12-20:
sleep is a important think. Thank you a lot
