Are there existing functions to convert from camera info arrays of K and D to intrinsic and distortion cv::Mats that can be passed into opencv functions like projectPoints()?
I'm interested in C++ mainly but python would also be useful.
I have my own implementations including https://github.com/lucasw/image_manip/blob/d61a01452ac4d46da132494f2c1516703ea83899/image_manip/src/distort.cpp#L41-L72https://github.com/lucasw/image_manip/blob/master/image_manip/src/distort.cpp#L72-L103 but ideally it would do the right thing with binning and roi.
https://github.com/ros-perception/vision_opencv/blob/noetic/image_geometry/src/pinhole_camera_model.cpp#L97-L223 looks like what I want but the class interface is in the way and it can't be used directly (and I'm not interested in subclassing it)- there's even a usage of projectPoints: https://github.com/ros-perception/vision_opencv/blob/noetic/image_geometry/src/pinhole_camera_model.cpp#L360-L382 - but I want to do something different with projecting points than that. I can rip that code out and make it functional and will leave it in image_manip so other packages could use it- unless that exists somewhere already.
Originally posted by lucasw on ROS Answers with karma: 8729 on 2022-10-24
This is a first pass at adapting the image_geometry code: https://github.com/lucasw/image_manip/blob/master/image_manip/src/utility.cpp#L39-L105 - very little testing so far though:
std::vector image_points;
cv::Matx33d intrinsic;
cv::Mat distortion;
image_manip::cameraInfoToCV(msg, intrinsic, distortion);
cv::Mat rvec, tvec = cv::Mat_<double>::zeros(3, 1);
cv::Rodrigues(R_.t(), r_vec);
cv::projectPoints(vector_of_3d_points_in_camera_frame,
    rvec, tvec, intrinsic, distortion, image_points);
Copy of the function code:
// adapted from https://github.com/ros-perception/vision_opencv/blob/noetic/image_geometry/src/pinhole_camera_model.cpp fromCameraInfo
void cameraInfoToCV(const sensor_msgs::CameraInfo::ConstPtr& msg,
    cv::Matx33d& K_,  // Describe current image (includes binning, ROI)
    cv::Mat_<double>& D_)  // Unaffected by binning, ROI - they are in ideal camera coordinates
  // TODO(lucasw) this can't be const
  auto cam_info = *msg;
  cv::Matx34d P_;  // Describe current image (includes binning, ROI)
  int d_size = cam_info.D.size();
  D_ = (d_size == 0) ? cv::Mat_<double>() : cv::Mat_<double>(1, d_size, cam_info.D.data());
  auto K_full_ = cv::Matx33d(&cam_info.K[0]);
  // TODO(lucasw) not actually using P_full_
  auto P_full_ = cv::Matx34d(&cam_info.P[0]);
  // Binning = 0 is considered the same as binning = 1 (no binning).
  const uint32_t binning_x = cam_info.binning_x ? cam_info.binning_x : 1;
  const uint32_t binning_y = cam_info.binning_y ? cam_info.binning_y : 1;
  // ROI all zeros is considered the same as full resolution.
  sensor_msgs::RegionOfInterest roi = cam_info.roi;
  if (roi.x_offset == 0 && roi.y_offset == 0 && roi.width == 0 && roi.height == 0) {
    roi.width  = cam_info.width;
    roi.height = cam_info.height;
  // If necessary, create new K_ and P_ adjusted for binning and ROI
  /// @todo Calculate and use rectified ROI
  const bool adjust_binning = (binning_x > 1) || (binning_y > 1);
  const bool adjust_roi = (roi.x_offset != 0) || (roi.y_offset != 0);
  if (!adjust_binning && !adjust_roi) {
    K_ = K_full_;
    P_ = P_full_;
  } else {
    K_ = K_full_;
    P_ = P_full_;
    // ROI is in full image coordinates, so change it first
    if (adjust_roi) {
      // Move principal point by the offset
      /// @todo Adjust P by rectified ROI instead
      K_(0,2) -= roi.x_offset;
      K_(1,2) -= roi.y_offset;
      P_(0,2) -= roi.x_offset;
      P_(1,2) -= roi.y_offset;
    if (binning_x > 1) {
      const double scale_x = 1.0 / binning_x;
      K_(0,0) *= scale_x;
      K_(0,2) *= scale_x;
      P_(0,0) *= scale_x;
      P_(0,2) *= scale_x;
      P_(0,3) *= scale_x;
    if (binning_y > 1) {
      const double scale_y = 1.0 / binning_y;
      K_(1,1) *= scale_y;
      K_(1,2) *= scale_y;
      P_(1,1) *= scale_y;
      P_(1,2) *= scale_y;
      P_(1,3) *= scale_y;
Originally posted by lucasw with karma: 8729 on 2022-10-24
