I'm trying to port my work from ROS1 (noetic) to ROS2 (galactic). I've met some problem when I try to implement some custom algorithms (YOLOv5, which is a little complicate, contains many subfolders and scripts) to my image subscriber.
Under ROS1 since the Python node is exactly the executable python script itself, there would be no problems with the imported scripts. But ROS2, via colcon build, the node files to be executed are generated to /colcon_ws/install. Therefore there would be problems about linking our custom python modules to the ros node.
I've already tried to modify the setup.py following these blogs:
  • Including a Python module in a ROS2 package
  • ROS2 Python relative import of my scritps
    and now my setup.py looks like:
    from setuptools import setup from setuptools import find_packages
    package_name = 'yolov5_detect' submodules = 'yolov5_detect/yolov5'
    setup( name=package_name, version='0.0.0', # packages=[package_name, submodules], packages=find_packages(), # include_package_data=True, data_files=[ ('share/ament_index/resource_index/packages', ['resource/' + package_name]), ('share/' + package_name, ['package.xml']), ], install_requires=['setuptools'], zip_safe=True, maintainer='jun', maintainer_email='[email protected]', description='TODO: Package description', license='TODO: License declaration', tests_require=['pytest'], entry_points={ 'console_scripts': [ 'webcam_yolo_pub=yolov5_detect.webcam_yolo_pub:main', 'webcam_yolo_sub=yolov5_detect.webcam_yolo_sub:main' ], }, )
the folder structure:
yolov5_detect
└── yolov5_detect
    ├── image_utils.py
    ├── __init__.py
    ├── webcam_yolo_pub.py
    ├── webcam_yolo_sub.py
    └── yolov5
       └── \utils
       └── \models
├── MANIFEST.in
├── package.xml
├── resource
│   └── yolov5_detect
├── setup.cfg
├── setup.py
and in /install the folder yolov5 is also successfully built. Still, when I run the subscriber node, it complains:
$ ~/ros2_guyue/colcon_ws$ ros2 run yolov5_detect webcam_yolo_sub
  File "/home/jun/ros2_guyue/colcon_ws/install/yolov5_detect/lib/yolov5_detect/webcam_yolo_sub", line 33, in <module>
    sys.exit(load_entry_point('yolov5-detect==0.0.0', 'console_scripts', 'webcam_yolo_sub')())
  File "/home/jun/ros2_guyue/colcon_ws/install/yolov5_detect/lib/yolov5_detect/webcam_yolo_sub", line 25, in importlib_load_entry_point
    return next(matches).load()
  File "/usr/lib/python3.8/importlib/metadata.py", line 77, in load
    module = import_module(match.group('module'))
  File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
  File "<frozen importlib._bootstrap>", line 991, in _find_and_load
  File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 848, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/home/jun/ros2_guyue/colcon_ws/install/yolov5_detect/lib/python3.8/site-packages/yolov5_detect/webcam_yolo_sub.py", line 12, in <module>
    from yolov5.detect_ros import Yolov5Detector
ModuleNotFoundError: No module named 'yolov5'
the "import" part of my ros node script:
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Image
from cv_bridge import CvBridge
import cv2
import numpy as np
from image_utils import *
the "import" part of the custom class script detect_ros.py:
from utils.plots import Annotator, colors, save_one_box
from utils.general import (check_img_size, non_max_suppression, scale_coords, LOGGER)
from utils.torch_utils import select_device, time_sync
from models.common import DetectMultiBackend
import os
Originally posted by junmeng on ROS Answers with karma: 36 on 2022-10-18
I've solved this with the following steps:
    1. modify setup.py to ensure my yolov5 folder also be compiled into /install
    1. modify from xxx import xxx in ALL the relevant scripts in yolov5, add '<package_name>.<submodule_name>. ahead of folder name, like:
    --> MODIFY: add '<package_name>.<submodule_name>. ahead
    from yolov5_detect.yolov5.utils.plots import Annotator, colors, save_one_box
With this the node can just struggle to run. It's not very elegant. I'm looking for a more efficient way to do so.
Originally posted by junmeng with karma: 36 on 2022-10-20
