I'm trying to access the pose of cube in gazebo using /gazebo/model_states. There is a large error between the reported result by /gazebo/model_states and Gazebo GUI. Take a look at the following picture. The GUI shows 0.758 and /gazebo/model_states gives 0.369. I need to use this data as ground truth but from what I'm noticing, I need to make sure there is no discrepancy. Any suggestions?
Melodic, Gazebo 9, Ubuntu 18.04.
image description
Originally posted by CroCo on ROS Answers with karma: 155 on 2022-09-08
These look correct to me. Gazebo is reporting axis-angle in radians, while /gazebo/model_states is reporting quaternions. You can do a manual transform here to see that they are the same: https://www.andre-gaschler.com/rotationconverter/.
Originally posted by Ronoman with karma: 48 on 2022-09-08
