Here is my script
#!/usr/bin/env python3
import rospy
import rospy
from std_msgs.msg import Float64
def talker():
    pub = rospy.Publisher('/rx150/wrist_rotate_controller/command', Float64, queue_size=10)
    rospy.init_node('rx150_talker', anonymous=True)
    rate = rospy.Rate(10)
        position = -1.0
        rospy.loginfo(position)
        pub.publish(position)
        rate.sleep()
if __name__ == '__main__':
    try:
        talker()
    except rospy.ROSInterruptException:
        pass
When executing this script the gazebo simulated robot doesn't respond to the joint command I give.
The simulated robot however does respond to this command when I type it in the terminal:
rostopic pub -1 /rx150/wrist_angle_controller/command std_msgs/Float64 "data: -1.0"
Originally posted by PGTKing on ROS Answers with karma: 13 on 2022-08-11
Your ROS node talker uses different topic than your terminal command, in node you have /rx150/wrist_rotate_controller/command and in the rostopic you have /rx150/wrist_angle_controller/command.
You can check if you are publishing everything correctly with rostopic echo.
Originally posted by ljaniec with karma: 3064 on 2022-08-12
Comment by PGTKing on 2022-08-12:
Thank you, sometimes you overlook small mistakes. Appreciate it.
