Hi I have x-box controller connected and topic echo's just fine.
I can even drive my bot around > teleop_twist_joy. So now I want to use the buttons on joy stick to move a servo and switch lights on/off.
I started a node witch compiles just fine but I am stuck on subscribing to joy sensor mseg. If I can get to the buttons info I would like to publish to "servo" topic to move servo (value from 0-180) ---later
For know just need to access joy_node.
 #include <ros/ros.h>
 #include <sensor_msgs/Joy.h>    // use to subscribe joy topic
 #include <std_msgs/UInt8.h>    //use to publish to servo topic
 void joyCallback(const sensor_msgs::Joy::ConstPtr& joy)
   //   if (msg.buttons[0] == 1) {
   //        ROS_INFO("Button 0 pressed...");
//std::cout<<"axes: ["<< joy->axes[0] <<","<<joy->axes[1] <<","<<joy->axes[2] <<"<<"]"<<std::endl;
//std::cout<<"buttons: ["<<  joy->buttons[0]  <<","<< joy->buttons[1] <<ns[   <<"]"<<std::endl;
ros::init(argc, argv, "servo_controle_node");
ros::NodeHandle n("~");
ros::Rate loop_rate(50);
ros::Subscriber sub = n.subscribe("joy", 10, joyCallback);
ROS_INFO_ONCE("print out test");
//joyCallback(); //read joystick buttons
while (ros::ok())
    ros::spinOnce();
    loop_rate.sleep();
So if I can get the this= ros::Subscriber sub = n.subscribe("joy", 10, joyCallback); write then maybe I can access the buttons in the joyCallback function. Trolled the net with google and the "remote teleop node" or "simple plublisher/sebscriber node" not helping much
Update: Thanks Ravi Joshi your help apreciated. I solved it before I got back to update this post. so the new code....
/*void stickCallback (const sensor_msgs::Joy::ConstPtr& msg)
        for (unsigned i = 0; i < msg->axes.size(); ++i)
             ROS_INFO("Axis %d is now at position %f", i, msg->axes[i]);
 /*void buttonCallback (const sensor_msgs::Joy::ConstPtr& msg)
         for (unsigned i = 0; i < msg->buttons.size(); ++i) {
             ROS_INFO("button %d is now at position %d", i, msg->buttons[i]);
 void servo_moveCallback(const sensor_msgs::Joy::ConstPtr &msg)  //while loop dont play nice
                 //int a = msg->buttons[2];
                 int b = msg->buttons[1];
                 if (msg->buttons[2] == 1)
                       ROS_INFO("panning servo left publish");
                 else if ( b == 1  )
              ROS_INFO("panning servo right publish");
    created while sorting out left and right > keeping it around for up/down tilt
 void servo2_moveCallback(const sensor_msgs::Joy::ConstPtr &msg)
       if (msg->buttons[3] == 1)
      ROS_INFO("tilting servo up publish");
      else if ( msg->buttons[0]== 1  )
            ROS_INFO("tilting servo down publish");
  ros::NodeHandle nh;
 // ros::Subscriber sub = nh.subscribe("joy",10, stickCallback);    //test function to access joy sticks
 // ros::Subscriber sub2 = nh.subscribe("joy",10, buttonCallback);  //test function to access buttons
 ros::Subscriber sub3 = nh.subscribe("joy", 10, servo_moveCallback);
 ros::Subscriber sub4 = nh.subscribe("joy",10, servo2_moveCallback);
  ROS_INFO_ONCE("Servo_controle_node Started");
  while (ros::ok())
    ros::spinOnce();
   loop_rate.sleep();
Ok, so first two functions (commented out) shows axis and buttons avail. Useful for mapping element to button pressed. The next call specific buttons and action a print to screen. Short and sweet: main: create a subscriber with function name> create function: of void type.... int and such wasn't successful and while loops in function calls don't play nice.
Originally posted by TK hobby on ROS Answers with karma: 15 on 2022-07-29
You are on the right track.
  1. You need to create a subscriber as you have done it already. However, please note that the callback function will be called automatically upon receiving data from your joystick. Therefore, you don't need to call the callback function by yourself.
  2. Next, you can look up the message definition of sensor_msgs/Joy. Finally, the buttons and axes array contains button measurements and axes measurements from a joystick, respectively. In the past, I found the mappings of buttons and axes by pressing each of them one by one while echoing the joy topic.
  3. Once you find the correct mapping, you should trigger the lights on/off, etc.
Update
The message you are receiving is a pointer type. The buttons and axes are array variables. So you can iterate over them to find their mappings. See below the code snippet:
for(const auto & button : joy->buttons){
    // you can print button here
Once you find the correct mapping, say you are interested in a button at index 1, use a conditional statement as shown below:
auto button = joy->buttons[1]
if (button == 1){
    // trigger light on here
Originally posted by ravijoshi with karma: 1744 on 2022-07-29
Comment by TK hobby on 2022-07-29:
Had a look and visited that page in my extensive googling. It only tells me that the "int32[] buttons", So.. I should a=int32[0] buttons or do I create an aray/list equel to int32[]buttons
Can you point me to a tutorial where they used buttons?
Comment by ravijoshi on 2022-07-30:
I updated my answer. Please see the update section. For tutorials, it is always advised to check official wiki page. Please feel free to look at http://wiki.ros.org/joy and http://wiki.ros.org/joystick_drivers/Tutorials
Comment by ravijoshi on 2022-08-01:
It is advised to click on "up vote" and "accept answer" instead of editing the title saying "[Solved]"
