I'm trying to display a cube interactive marker using the interactive_marker_tutorials (have to build from source). Running the cube example:
ros2 run interactive_marker_tutorials cube
Then, running rviz:
rviz2
Add an interactive marker display with namespace set to cube, and RViz spams the following and the interactive marker doesn't show:
[INFO] [1657456819.061519998] [rviz]: Sending request for interactive markers
[INFO] [1657456819.093636879] [rviz]: Service response received for initialization
[INFO] [1657456819.124743724] [rviz]: Sending request for interactive markers
[INFO] [1657456819.158057054] [rviz]: Service response received for initialization
Originally posted by ijnek on ROS Answers with karma: 460 on 2022-07-10
The issue is due to no TF data to transform the interactive marker's in the base_link frame to the map frame RViz is trying to display.
Simply change the Fixed Frame to base_link in RViz:
image description
Originally posted by ijnek with karma: 460 on 2022-07-10
