Configuration
  • ROS Distro: Humble
  • OS Version: Ubuntu 22.04
Description
Hi, I am trying to create a hardware_interface plugin for ros2_control. I want to create a publisher to write() and a subscriber to read(). I am running into issues setting up the subscriber. Then code is given below.
Code
#include
#include
#include
#include "rclcpp/rclcpp.hpp"
#include "std_msgs/msg/float64.hpp"
#include "sensor_msgs/msg/joint_state.hpp"
#include "custom_interfaces/msg/motor_command.hpp"
#include "test_hardware_interface/test_hardware_interface.hpp"
#include "hardware_interface/actuator_interface.hpp"
#include "hardware_interface/types/hardware_interface_type_values.hpp"
using namespace hardware_interface;
static const auto LOGGER = rclcpp::get_logger("Grab-Hardware");
namespace test_hardware_interface
  //HardwareComms Methods
  HardwareComms::HardwareComms() : Node("joint_comms")
    //Lamda callback for stateSub_
    auto stateCB =
      [this](const std_msgs::msg::Float64::SharedPtr state) -> void
        RCLCPP_INFO(this->get_logger(), "Callback");
        state_ = state->data;
    commandPub_ = this->create_publisher(
      "/test_pub",
    stateSub_ = this->create_subscription(
      "/test_sub",
      0,
      stateCB
  void HardwareComms::sendCommand(double position, double velocity, double acceleration)
    auto command = custom_interfaces::msg::MotorCommand();
    command.position = position;
    command.velocity = velocity;
    command.acceleration = acceleration;
    commandPub_->publish(command);
  double HardwareComms::getState()
    return state_;
  //HardwareInterface Methods
  CallbackReturn HardwareInterface::on_init(const hardware_interface::HardwareInfo &info)
    RCLCPP_INFO(LOGGER, "Initialising...");
    if(
      hardware_interface::ActuatorInterface::on_init(info) !=
        hardware_interface::CallbackReturn::SUCCESS)
      return hardware_interface::CallbackReturn::ERROR;
    comms = std::make_shared();
    hw_joint_state_           = std::numeric_limits::quiet_NaN();
    hw_position_command_      = std::numeric_limits::quiet_NaN();
    hw_velocity_command_      = std::numeric_limits::quiet_NaN();
    hw_acceleration_command_  = std::numeric_limits::quiet_NaN();
    const ComponentInfo &joint = info_.joints[0];
    if(joint.command_interfaces.size() != 3) {
      RCLCPP_FATAL(
        LOGGER,
        "Joint '%s' has %zu command interfaces found. 3 expected.", joint.name.c_str(),
    RCLCPP_INFO(LOGGER, "Checking Position IF");
    if (joint.command_interfaces[0].name != hardware_interface::HW_IF_POSITION) {
      RCLCPP_FATAL(
        LOGGER,
        "Joint '%s' have %s command interfaces found. '%s' expected.", joint.name.c_str(),
        joint.command_interfaces[0].name.c_str(), hardware_interface::HW_IF_POSITION
    RCLCPP_INFO(LOGGER, "Clear!");
    RCLCPP_INFO(LOGGER, "Checking Velocity IF");
    if (joint.command_interfaces[1].name != hardware_interface::HW_IF_VELOCITY) {
      RCLCPP_FATAL(
        LOGGER,
        joint.command_interfaces[1].name.c_str(), hardware_interface::HW_IF_VELOCITY
    RCLCPP_INFO(LOGGER, "Checking Acceleration IF");
    if (joint.command_interfaces[2].name != hardware_interface::HW_IF_ACCELERATION) {
      RCLCPP_FATAL(
        LOGGER,
        joint.command_interfaces[2].name.c_str(), hardware_interface::HW_IF_ACCELERATION
    if (joint.state_interfaces.size() != 1) {
      RCLCPP_FATAL(
        LOGGER, "Joint '%s' has %zu state interface. 1 expected.",
        joint.name.c_str(), joint.state_interfaces.size());
    if (joint.state_interfaces[0].name != hardware_interface::HW_IF_POSITION) {
      RCLCPP_FATAL(
        LOGGER, "Joint '%s' have %s state interface. '%s' expected.",
        joint.name.c_str(), joint.state_interfaces[0].name.c_str(),
        hardware_interface::HW_IF_POSITION);
    RCLCPP_INFO(LOGGER, "Done!");
    return hardware_interface::CallbackReturn::SUCCESS;
  CallbackReturn HardwareInterface::on_configure(const rclcpp_lifecycle::State & /*previous_state*/)
    RCLCPP_INFO(LOGGER, "Configuring...");
  std::vector HardwareInterface::export_state_interfaces()
    std::vector state_interfaces;
    state_interfaces.emplace_back(hardware_interface::StateInterface(
      info_.joints[0].name, hardware_interface::HW_IF_POSITION, &hw_joint_state_));
    return state_interfaces;
  std::vector HardwareInterface::export_command_interfaces()
    std::vector command_interfaces;
    command_interfaces.emplace_back(hardware_interface::CommandInterface(
      info_.joints[0].name, hardware_interface::HW_IF_POSITION, &hw_position_command_));
      info_.joints[0].name, hardware_interface::HW_IF_VELOCITY, &hw_velocity_command_));
      info_.joints[0].name, hardware_interface::HW_IF_ACCELERATION, &hw_acceleration_command_));
    return command_interfaces;
  CallbackReturn HardwareInterface::on_activate(const rclcpp_lifecycle::State & /*previous_state*/)
    if (std::isnan(hw_joint_state_)) {
      hw_joint_state_ = 0.0;
      hw_position_command_ = 0.0;
      hw_velocity_command_ = 5.0;
      hw_acceleration_command_ = 0.0;
    RCLCPP_INFO(LOGGER, "Successfully activated!");
  CallbackReturn HardwareInterface::on_deactivate(
    RCLCPP_INFO(LOGGER, "Successfully deactivated!");
  return_type HardwareInterface::read(
    const rclcpp::Time & /*time*/,
    const rclcpp::Duration & /*period*/)
    hw_joint_state_ = comms->getState();
    RCLCPP_INFO(rclcpp::get_logger("HardwareRead"), "State: %f", hw_joint_state_);
    return hardware_interface::return_type::OK;
  return_type HardwareInterface::write(
    comms->sendCommand(hw_position_command_, hw_velocity_command_, hw_acceleration_command_);
} //namespace grab_hardware
#include "pluginlib/class_list_macros.hpp"
PLUGINLIB_EXPORT_CLASS(test_hardware_interface::HardwareInterface, hardware_interface::ActuatorInterface)
The publisher works fine, but the callback of the subscriber does not get called. Am I missing something? Any help is appreciated Thank you.
Originally posted by Cryoschrome on ROS Answers with karma: 75 on 2022-06-28
I specified a new node to handle communication to and from the hardware interface. Since the an executor is necessary to spin the node, I defined one in the hardware interface component and executed it in a detached thread. ###joint_hardware_interface.hpp
#ifndef JOINT_HARDWARE_INTERFACE
#define JOINT_HARDWARE_INTERFACE
#include <memory>
#include <string>
#include <vector>
#include "rclcpp/macros.hpp"
#include "rclcpp_lifecycle/node_interfaces/lifecycle_node_interface.hpp"
#include "rclcpp_lifecycle/state.hpp"
#include "joint_limits/joint_limits.hpp"
#include
namespace join_hardware_interface
  class JointComms : public rclcpp::Node
    public:
       * @brief Constructor a new Grab Joint Comms object
      JointComms();
       * @brief Create the msg and publish to MCU
      void sendCommand(double position, double velocity, double acceleration);
       * @brief Position and velocity getters
      double getPosition();
      double getVelocity();
    private:
      double position_;
      double velocity_;
      rclcpp::Subscription::SharedPtr stateSub_;
      rclcpp::Publisher::SharedPtr commandPub_;
  class JointHardware : public hardware_interface::ActuatorInterface
    public:
      JointHardware();
      CallbackReturn on_configure(const rclcpp_lifecycle::State &previous_state);
      CallbackReturn on_activate(const rclcpp_lifecycle::State &previous_state);
      CallbackReturn on_deactivate(const rclcpp_lifecycle::State &previous_state);
      CallbackReturn on_init(const hardware_interface::HardwareInfo &info);
      std::vector export_state_interfaces() override;
      std::vector export_command_interfaces() override;
      hardware_interface::return_type read(
        const rclcpp::Time & time, const rclcpp::Duration & period) override;
      hardware_interface::return_type write(
      std::shared_ptr<JointComms> comms;
    private:
      rclcpp::executors::SingleThreadedExecutor executor_;  //Executor needed to subscriber
      double hw_position_command_;
      double hw_velocity_command_;
      double hw_acceleration_command_;
      double hw_position_state_;
      double hw_velocity_state_;
      int setSpeed_;
      int setAccelaration_;
      bool isActive_;
      joint_limits::JointLimits limits;
and in the .cpp file, within the on_init() function, I created the thread.
    comms = std::make_shared<JointComms>();
    executor_.add_node(comms);
    std::thread([this]() { executor_.spin(); }).detach();
Originally posted by Cryoschrome with karma: 75 on 2023-02-02
