Test Env: ROS2 Galactic ; Ubuntu 20.04
Target: I am attempting to trigger a ROS2 Service from within an ROS2 Action server callback.
A single ROS2 Action goal shall trigger multiple ROS2 service calls in a sequence. Currently, I am facing errors as shown below when I execute a ROS Action goal.
ERROR: terminate called after throwing an instance of 'std::runtime_error' what(): Node has already been added to an executor.
Can any one suggest a solution to this issue?
// Code structure below
class MoveActionServer : public rclcpp::Node{
    public:
// Instantiate an action server
private:
// Action Server Callback
void execute_cb(){
    // Create a ROS2 Service Client
    service_client_ = this->create_client<action_interfaces::srv::Move>("move");
            // While loop to calls the Service multiple times
    while(rclcpp::ok() && count < target_count){
        // Calling the Move ROS2 Service
        req.x = val1;
        req.y = val2;
        // Wait for ROS2 Service
        while(!service_client_ -> wait_for_service(1s)){
        // Send Request to ROS2 Service
        auto res = service_client_ -> async_send_request(req);
        // Wait for response from ROS2 Service
        // *CAUSE FOR ERROR*
        if (rclcpp::spin_until_future_complete(this->get_node_base_interface(), poseError) ==
                    rclcpp::FutureReturnCode::SUCCESS) {
                RCLCPP_INFO(get_logger(), "Response: %d", poseError.get()->error);
                else {
                RCLCPP_INFO(get_logger(), "Failed to call Move Service");
    count ++;
int main(int argc, char *argv[]) {
    rclcpp::init(argc, argv);
    auto node = std::make_shared<MoveActionServer>();
    rclcpp::spin(node);
    rclcpp::shutdown();
    return 0;
Originally posted by audupi on ROS Answers with karma: 36 on 2022-06-14
I have managed to solve this issue.
ROS2 has defined new concepts called callback_groups to enable calling of a service/action from within a ROS2 callback. I have created a callback_group of type Reentrant as shown below
my_callback_group_ = this->create_callback_group(rclcpp::CallbackGroupType::Reentrant);
and then link the service_client to the above defined callback group
service_client_ = this->create_client<std_srvs::srv::Empty>("test_service", rmw_qos_profile_services_default, my_callback_group_);
https://docs.ros.org/en/foxy/How-To-Guides/Using-callback-groups.html
The link above provides a detailed explanation as to how this implementation can be achieved! I hope this helps.
Originally posted by audupi with karma: 36 on 2022-06-30
