I am trying to configure a package that contains srv, msg, etc., files along with CPP. However, the compiler can not find generated files. Below is the complete error:
ravi@dell:~/ros2_ws$ colcon build --allow-overriding action_tutorials_cpp
Starting >>> action_tutorials_cpp
--- stderr: action_tutorials_cpp
/home/ravi/ros2_ws/src/action_tutorials_cpp/src/fibonacci_action_server.cpp:17:10: fatal error: action_tutorials_cpp/action/fibonacci.hpp: No such file or directory
17 | #include "action_tutorials_cpp/action/fibonacci.hpp"
compilation terminated.
make[2]: *** [CMakeFiles/action_tutorials.dir/build.make:63: CMakeFiles/action_tutorials.dir/src/fibonacci_action_server.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:152: CMakeFiles/action_tutorials.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
make: *** [Makefile:141: all] Error 2
Failed <<< action_tutorials_cpp [0.68s, exited with code 2]
Summary: 0 packages finished [0.84s]
1 package failed: action_tutorials_cpp
1 package had stderr output: action_tutorials_cpp
Please note that, the colcon was able to generate header file successfully, as shown below:
ravi@dell:~/ros2_ws$ find . -name fibonacci.hpp
./build/action_tutorials_cpp/rosidl_generator_cpp/action_tutorials_cpp/action/fibonacci.hpp
Surprisingly, the local_setup.bash shows the following error:
ravi@dell:~/ros2_ws$ source install/local_setup.bash
not found: "/home/ravi/ros2_ws/install/action_tutorials_cpp/share/action_tutorials_cpp/local_setup.bash"
Please see an example below (merged from action_tutorials_interfaces and action_tutorials_cpp):
CMakeLists.txt
cmake_minimum_required(VERSION 3.5)
project(action_tutorials_cpp)
find_package(rclcpp REQUIRED)
find_package(rclcpp_action REQUIRED)
find_package(rclcpp_components REQUIRED)
find_package(rosidl_default_generators REQUIRED)
rosidl_generate_interfaces(${PROJECT_NAME}
"action/Fibonacci.action")
include_directories(include)
add_library(action_tutorials SHARED
src/fibonacci_action_server.cpp)
rclcpp_components_register_node(action_tutorials PLUGIN "action_tutorials_cpp::FibonacciActionServer"
EXECUTABLE fibonacci_action_server)
target_compile_definitions(action_tutorials
PRIVATE "ACTION_TUTORIALS_CPP_BUILDING_DLL")
ament_target_dependencies(action_tutorials
"rclcpp"
"rclcpp_action"
"rclcpp_components")
install(TARGETS
action_tutorials
ARCHIVE DESTINATION lib
LIBRARY DESTINATION lib
RUNTIME DESTINATION bin)
if(BUILD_TESTING)
find_package(ament_lint_auto REQUIRED)
ament_lint_auto_find_test_dependencies()
endif()
ament_package()
package.xml
<?xml version="1.0"?>
<?xml-model href="http://download.ros.org/schema/package_format3.xsd" schematypens="http://www.w3.org/2001/XMLSchema"?>
<package format="3">
<name>action_tutorials_cpp</name>
<version>0.9.3</version>
<description>C++ action tutorial cpp code</description>
<maintainer email="[email protected]">Mabel Zhang</maintainer>
<maintainer email="[email protected]">Michael Jeronimo</maintainer>
<license>Apache License 2.0</license>
<author email="[email protected]">Jacob Perron</author>
<buildtool_depend>ament_cmake</buildtool_depend>
<buildtool_depend>rosidl_default_generators</buildtool_depend>
<depend>rclcpp</depend>
<depend>rclcpp_action</depend>
<depend>rclcpp_components</depend>
<exec_depend>rosidl_default_runtime</exec_depend>
<test_depend>ament_lint_auto</test_depend>
<test_depend>ament_lint_common</test_depend>
<member_of_group>rosidl_interface_packages</member_of_group>
<export>
<build_type>ament_cmake</build_type>
</export>
</package>
CPP (head only)
#include "rclcpp/rclcpp.hpp"
#include "action_tutorials_cpp/visibility_control.h"
#include "rclcpp_action/rclcpp_action.hpp"
#include "rclcpp_components/register_node_macro.hpp"
namespace action_tutorials_cpp {
class FibonacciActionServer : public rclcpp::Node {
public:
using Fibonacci = action_tutorials_cpp::action::Fibonacci;
using GoalHandleFibonacci = rclcpp_action::ServerGoalHandle<Fibonacci>;
ACTION_TUTORIALS_CPP_PUBLIC
explicit FibonacciActionServer(
const rclcpp::NodeOptions& options = rclcpp::NodeOptions())
: Node("fibonacci_action_server", options) {
using namespace std::placeholders;
this->action_server_ = rclcpp_action::create_server<Fibonacci>(
this->get_node_base_interface(), this->get_node_clock_interface(),
this->get_node_logging_interface(),
this->get_node_waitables_interface(), "fibonacci",
std::bind(&FibonacciActionServer::handle_goal, this, _1, _2),
std::bind(&FibonacciActionServer::handle_cancel, this, _1),
std::bind(&FibonacciActionServer::handle_accepted, this, _1));
Package Structure
└── action_tutorials_cpp
├── action
│ └── Fibonacci.action
├── CMakeLists.txt
├── include
│ └── action_tutorials_cpp
│ └── visibility_control.h
├── package.xml
└── src
└── fibonacci_action_server.cpp
5 directories, 5 files
I want to know how to configure such a package in ROS2.
Originally posted by ravijoshi on ROS Answers with karma: 1744 on 2022-06-11
