I tried solution from @javisshultz
https://answers.ros.org/question/345764/e-unable-to-locate-package-ros-melodic-desktop-full-or-ros-melodic-desktop/
echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" | sudo tee /etc/apt/sources.list.d/ros-latest.list
sudo apt update
but unfortunately, after last cmd I keep getting
The repository 'http://packages.ros.org/ros/ubuntu jammy Release' does not have a Release file.
What can I do more ?
My system : Ubuntu 22.04 Humble Hawksbill
What is my goal -> image recognition using this node https://github.com/qboticslabs/rostensorflow
Originally posted by Orpiczy on ROS Answers with karma: 1 on 2022-06-02
You appear to be trying to use the ROS 1 package repository to install a ROS 2 package.
That doesn't work.
According to ros2/rolling/Installation: Ubuntu (Debian), the ROS 2 repository would be http://packages.ros.org/ros2/ubuntu, not http://packages.ros.org/ros/ubuntu.
I would suggest to verify you've correctly setup the ROS 2 repositories and followed the installation tutorial.
This is the same problem as in your other #q399935.
I tried solution from @javisshultz #q345764
the Q&A you link discusses a ROS 1 problem. It's not applicable to ROS 2.
Additionally:
Unable to locate package ros-humble-cv-camera
According to status_page/ros_humble_default.html?q=camera, cv_camera is not available in ROS 2 Humble.
Originally posted by gvdhoorn with karma: 86574 on 2022-06-03
Comment by wenchao on 2023-04-14:
I tried to solve the problem by repeating the curl and echo commands in the installation tutorial (https://docs.ros.org/en/humble/Installation/Ubuntu-Install-Debians.html), but to no avail. When I run "sudo apt-get install ros-$(rosversion -d)-turtlesim", it fails to fetch. When I run "sudo apt-get update", one of the lines reads "E: The repository 'http://packages.ros.org/ros/ubuntu jammy Release' does not have a Release file."
Comment by wenchao on 2023-04-15:
The answer from https://answers.ros.org/question/402151/the-repository-does-not-have-a-release-file/ worked.
First, check the ROS Index or type apt search ros-distro in your linux terminal to determine whether the ros-package is available for your ros-distro. Then, type sudo apt-get install ros-distro-package_name to install that package. After that, you can verify that the package has been installed by typing sudo apt-get rospack list-names or sudo apt-get rospack listto show the directory of the installed package. To check if it's up-to-date, typesudo apt update`to download the latest version of the package.
In your case, package cv_camera is not supported for ros-humble yet.
~Gundam Out.`
Comment by gvdhoorn on 2022-06-03:
The main problem reported by the OP is caused by the misconfiguration of the ROS package repositories.
You cannot install a ros-humble-... package from the ROS 1 package repositories. Regardless of whether it's released or not.
Comment by qilin_gundamenjoyer on 2022-06-03:
Yeah, I know that but when I typed this response, I was just trying to add on to your comment if the user ends up encountering an issue with installing a package even though the user installed from the correct ROS # package repository.
I'd at least mention #q320046 in that case.
Noted, I will keep in mind next time since I'm new to this community wiki. My bad.
Comment by gvdhoorn on 2022-06-04:
There is no need to apologise.
Comment by qilin_gundamenjoyer on 2022-06-04:
this might not be the right place to ask, but do you have any tips on getting good at debugging? I get that it all comes down to being practical at the end of the day but I would like to know if there are other ways that would help too.
I'm not sure I understand your comment.
"Debugging" in what way specifically?
learning how to solve errors and knowing what error is the problem
Comment by gvdhoorn on 2022-06-05:
Solving problems people have posted on ROS Answers ;)
But in reality: it's just experience.
Working with the tools/code/programs/infrastructure yourself, etc.
Comment by qilin_gundamenjoyer on 2022-06-05:
I lack the experience but I will try. I really want to get good with Robotics so yeah, thanks for the advice!
