I'm working now with UR5. When I echo the states of joints I get this
galf@galf:~/Desktop/ur5/catkin_ws$ rostopic echo /ur5/joint_states -n1
header:
  seq: 9465
  stamp:
    secs: 94
    nsecs: 662000000
  frame_id: ''
name: [elbow_joint, shoulder_lift_joint, shoulder_pan_joint, wrist_1_joint, wrist_2_joint,
  wrist_3_joint]
position: [-3.1415916305807485, 0.30983008014827096, 1.9488655889645834, 3.1415983918040062, 1.845209559572325, -3.141592812638949]
velocity: [3.621569639258467e-06, -9.772236883207112e-06, 0.00011501897260136615, -2.0719156311055294e-07, 0.06444979561546602, -6.340667138213241e-08]
effort: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
Are the positions match the joints in the same order as they appear in the names? I'm asking this because when I retrieve the info for the command topic, I get
galf@galf:~/Desktop/ur5/catkin_ws$ rostopic pub /ur5/joints_group_velocity_controller/command std_msgs/Float64MultiArray "layout:
  dim:
  - label: ''
    stride: 0
  data_offset: 0
data:
- 0"
So to command the joints, I need fill out data as data: [0,0,0,0,0,0] but I don't know the order of joints. How this works in ROS? Does data[0] represent elbow_joint?
The tree appears as shoulder_pan_joint > shoulder_lift_joint > elbow_joint > wrist_1_joint > wrist_2_joint > wrist_3_joint. I don't know why ROS puts them in alphabetical order.
Originally posted by CroCo on ROS Answers with karma: 155 on 2022-06-01
Comment by gvdhoorn on 2022-06-01:
I've updated the title to better reflect your question. "topic command" is too ambiguous.
From this:
galf@galf:~/Desktop/ur5/catkin_ws$ rostopic pub /ur5/joints_group_velocity_controller/command std_msgs/Float64MultiArray ...
it would appear you're using a JointGroupVelocityController with your driver (note: this cannot be ur_driver, as that's not a ros_control compatible driver).
That controller requires a configuration stanza similar to this:
joint_group_vel_controller:
   type: velocity_controllers/JointGroupVelocityController
   joints:
     - shoulder_pan_joint
     - shoulder_lift_joint
     - elbow_joint
     - wrist_1_joint
     - wrist_2_joint
     - wrist_3_joint
The order in which you should provide the data to the joints_group_velocity_controller/command would be the same order as specified in the configuration stanza I've included here.
this is not really "in ROS". It's just a consequence of how the ros_control developers implemented their infrastructure.
For this, see #q356347, #q282097, #q221560 and #q351105.
Originally posted by gvdhoorn with karma: 86574 on 2022-06-01
Comment by CroCo on 2022-06-01:
this is exactly my ymal file in the same order you've posted it.
Could you please confirm if the names match the positions' indices in the command topic?
Comment by gvdhoorn on 2022-06-02:
I'm not sure what is unclear about this:
Comment by CroCo on 2022-06-02:
@gvdhoorn, I'm talking about /joint_states.
Your question is still a bit ambiguous (which "names" are you referring to in your comment), but: please see #q356347, #q282097, #q221560 and #q351105.
Summarising: no, they don't have to, they probably don't, and you shouldn't assume they do or will.
