What is the correct way of multi threading in ROS2? As I understand it, ROS1 multi-threading was implicit.
I've been trying to find the convention for ROS2 of solving the following, relatively simple problem:
  1. Run a node which is running a practically forever loop.
  2. Have the node receive subscription callbacks succesfully.
An attempt was made by me here and I "solved" that (read: made it work - doesn't seem like the correct way) by forcing a call to rclpy.spin_once() inside the loop in (1). So, it clear to me that I need a better understanding of what is happening under the hood with ROS2. Can I put the main loop on a rate or something so that the spin procedure can run as intended? Where can I read more about this?
Another attempt was made as follows (see below), here am using threading in a raw manner, which also seems to "work" but also seems very rough around the edges. I also attempted to use MultiThreadedExector, however I fail to see how it is meant to help.
import rclpy
from rclpy.node import Node
from rclpy.executors import MultiThreadedExecutor
import threading
import time
class LoopRunner(Node):
  def __init__(self):
    super().__init__('loop_runnner')
    threading.Thread(target=self.run_loop).start()
  def run_loop(self):
    while True:
      #self.get_logger().info("I work")
      time.sleep(0.001)
      pass
class MinimalSubscriber(Node):
  def __init__(self):
    super().__init__('minimal_subscriber')
    self.subscription = self.create_subscription(
        String,
        'topic',
        self.listener_callback,
        10)
  def listener_callback(self, msg):
    self.get_logger().info('I heard: "%s"' % msg.data)
def main(args=None):
  rclpy.init(args=args)
  try:
    minimal_subscriber = MinimalSubscriber()
    loop_runner = LoopRunner()
    executor = MultiThreadedExecutor()
    executor.add_node(loop_runner)
    executor.add_node(minimal_subscriber)
    try:
      executor.spin()
    finally:
      executor.shutdown()
      minimal_subscriber.destroy_node()
      loop_runner.destroy_node()
  finally:
    rclpy.shutdown()
if __name__ == '__main__':
  main()
I guess this all comes down to better understanding the spinning process / callback queues and multi-threading of ROS2. I'll take any resources that can help out here as I've been looking around and while there is bits and pieces, I cannot find a comprehensive piece of code or documentation that paints the full picture.
Originally posted by printf42 on ROS Answers with karma: 23 on 2022-05-21
This post on the ROS Discourse
https://discourse.ros.org/t/how-to-use-callback-groups-in-ros2/25255
has a nice explanation for the SingleThreadedExecutor (default) and MultiThreadedExecutor next to the use of callback groups in ROS2. I hope it will help you.
Originally posted by ljaniec with karma: 3064 on 2022-05-23
Comment by printf42 on 2022-05-23:
That is a very informative resource, thank you very much.
Comment by gvdhoorn on 2022-05-24:
That's now being turned into a guide: ros2/ros2_documentation#2652.
@printf42: perhaps you have some comments you could share on the PR as a review?
