I have some toy code to test ROS2 action cancelation. I'm trying to send an action goal, then cancel it immediately. With print statements, I can verify that the action goal is received, but the cancellation callback does not run. The program hangs when the cancellation is requested.
Send the action goal:
auto goal_handle = std::get<1>(client_tuple)->async_send_goal(stage_request.hybrid_request, send_goal_options);
^don't worry about the tuple here. It's unconventional but it works.
Now try to cancel it immediately afterwards:
// I've tried a sleep() here. No change
auto cancellation_future = std::get<1>(client_tuple)->async_cancel_all_goals();
I have also tried this method of cancellation:
            auto cancellation_future = std::get<1>(client_tuple)->async_cancel_goal(goal_handle.get());
            if (rclcpp::spin_until_future_complete(m_node, cancellation_future) !=
                rclcpp::FutureReturnCode::SUCCESS)
                // This does not print:
                RCLCPP_INFO(LOGGER, "FAILED TO CANCEL!");
            // This does not print, it is stuck above this line:
            RCLCPP_INFO(LOGGER, "CANCELED");
My action server is set up like so:
  hybrid_planning_request_server_ = rclcpp_action::create_server<moveit_msgs::action::HybridPlanner>(
      this->get_node_base_interface(), this->get_node_clock_interface(), this->get_node_logging_interface(),
      this->get_node_waitables_interface(), hybrid_planning_action_name,
      // Goal callback
      [](const rclcpp_action::GoalUUID& /*unused*/,
         std::shared_ptr<const moveit_msgs::action::HybridPlanner::Goal> /*unused*/) {
        // This does print
        RCLCPP_INFO(LOGGER, "Received goal request");
        return rclcpp_action::GoalResponse::ACCEPT_AND_EXECUTE;
      // Cancel callback
      [this](std::shared_ptr<rclcpp_action::ServerGoalHandle<moveit_msgs::action::HybridPlanner>> /*unused*/) {
        RCLCPP_INFO(LOGGER, "Received request to cancel global goal manager");
        return rclcpp_action::CancelResponse::ACCEPT;
Originally posted by AndyZe on ROS Answers with karma: 2331 on 2022-05-18
Comment by AndyZe on 2022-05-18:
I wonder if I need to add another spinning thread? Or, somebody else tipped me off that the callbacks may be in the same group? I don't know what that means/how to fix it.
I've tried a MultiThreadedExecutor now. Still no luck.
Comment by jschornak on 2022-05-18:
Can you post the full source code for your test files? Like you mentioned, the behavior of the executor and the callback groups are important here.
I dropped some code in to verify the goal is accepted. This never prints, so it looks like the problem is the action server not responding:
if (rclcpp_action::GoalStatus::STATUS_ACCEPTED != future_goal_handle.get()->get_status())
    RCLCPP_ERROR_STREAM(LOGGER, "Goal was not accepted");
    return;
RCLCPP_ERROR_STREAM(LOGGER, "Goal was accepted!");
@jschornak code for the action server which is not responding is here: https://github.com/ros-planning/moveit2/blob/5a39a7f6ce84ce1ec17567ff5593ca9d376b21b6/moveit_ros/hybrid_planning/hybrid_planning_manager/hybrid_planning_manager_component/src/hybrid_planning_manager.cpp#L147
There's a solution in this PR:
https://github.com/ros-planning/moveit2/pull/1272
A quick-and-dirty fix is to move long-running callbacks into a detached thread, like in this rclcpp demo: https://github.com/AndyZe/examples/blob/14c743af8bbca6a40e83da7a470c5332dce66d9d/rclcpp/actions/minimal_action_server/member_functions.cpp#L110
And also to make sure each action server (if you have several) has its own callback group.
Originally posted by AndyZe with karma: 2331 on 2022-05-26
