I'm trying to do the same as this example : https://answers.ros.org/question/39523/rospackagegetpath-problem/
The function is documented here : http://docs.ros.org/en/jade/api/roslib/html/c++/namespaceros_1_1package.html
I created a minimum reproductible example of my problem, which I tested both on Kinetic and Noetic :
test.cpp :
#include <iostream>
#include <ros/package.h>
   std::cout << "Hello, world!" << std::endl;
   std::string testString = ros::package::getPath("testPath");
   std::cout << "Package path is "  << testString << std::endl;
Package.xml :
<?xml version="1.0"?>
<package format="2">
<name>testPath</name>
<version>0.0.0</version>
<description>The testPath package</description>
<maintainer email="[email protected]">victor</maintainer>
<license>TODO</license>
<buildtool_depend>catkin</buildtool_depend>
<build_depend>roscpp</build_depend>
<build_depend>roslib</build_depend>
<build_export_depend>roscpp</build_export_depend>
<build_export_depend>roslib</build_export_depend>
<exec_depend>roscpp</exec_depend>
<exec_depend>roslib</exec_depend>
<export>
  <!-- Other tools can request additional information be placed here -->
</export>
</package>
CmakeList :
cmake_minimum_required(VERSION 3.0.2)
project(testPath)
  roscpp
  roslib
catkin_package(
#  INCLUDE_DIRS include
#  LIBRARIES testPath
#  CATKIN_DEPENDS roscpp roslib
#  DEPENDS system_lib
include_directories(
# include
  ${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
#   src/${PROJECT_NAME}/testPath.cpp
add_executable(${PROJECT_NAME}_node src/test.cpp)
The linking error I'm getting :
undefined reference to « ros::package::getPath(std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&) »
Any leads on how to make this work?
Originally posted by Vic on ROS Answers with karma: 71 on 2022-05-03
Where do you call target_link_libraries(... ${catkin_LIBRARIES}) in your CMakeLists.txt?
Originally posted by gvdhoorn with karma: 86574 on 2022-05-03
Comment by Vic on 2022-05-04:
You were right. Adding
target_link_libraries(${PROJECT_NAME}_node
   ${catkin_LIBRARIES}
in the CmakeLists.txt fixed the issue. I expected it to be done automatically when created the package. Thanks
As @gvdhoorn pointed, I was missing the target_link_libraries in CmakeList.txt
Comment by Joe28965 on 2022-05-04:
If gvdhoorn answered your question, please accept it as an answer. Thanks in advance
