I want to implement a triggered / on-demand / on-request communication with hardware using ros2_control framework.
In relation to a previous question and this answer on a similar problem, i wrote a controller following forward_command_controller implementation for ros2 galactic, which uses a "settings" command interface type and calls LoanedCommandInterface.set_value(msg->data) whenever a new message msg arrives on the controller's subscribed topic.
On the hardware component side, I exported the "settings" command interface and, inside the write() method I check if a new "setting" has been commanded like so:
if (!std::isnan(hw_command_settings_))
  int setting = hw_command_settings_;
  switch (setting)
    case MY_FIRST_SETTING:
       *perform setting command
      break;
  hw_command_settings_ = std::numeric_limits<double>::quiet_NaN(); //reset setting request
  return hardware_interface::return_type::OK;
//write() function continues with the other command interfaces...
If the implementation is real-time, there's no problem: the hardware component writes using the other standard interfaces ("position", "velocity"...), and only if I send a message on the "/settings_controller/command" topic the setting command is performed.
However, the nature of these "settings" commands is not really real-time. I have a homing/calibrating command that needs to wait until the motor reaches a defined position before it's completed. So the write() function is blocked until this action is finished. However, when the normal control cycle is restored, i see a list of write() and read() calls that has been accumulating during this halting period (e.g. 5s halting with 10Hz control cycle results in 50 instant write() and read() calls after the halt). I believe this is like a default policy of ros2_control_node, but I'm very new to the framework and I don't really know.
Is there a way to avoid accumulating read() and write() calls when one of them is halted by a long procedure? If not, is there a way to isolate the "settings" interface so that the write() method is kept real-time? Any other suggestion is really helpful.
Thanks!
Originally posted by eldavio on ROS Answers with karma: 13 on 2022-05-02
We have recently extended read/write with time parameters. This should allow you to implement some mechanism to skip writing certain interfaces by keeping accounts of the last time you accessed them.
https://github.com/ros-controls/ros2_control/pull/715
Available in Humble and Rolling
Originally posted by Bence Magyar with karma: 358 on 2022-06-01
