I am busy doing an assignment for school however I am running into an issue. I have a very basic proof of concept to which I have created a test using the google test framework.
When I run colcon test and colcon test-result it says "Summary: 4 tests, 0 errors, 0 failures, 0 skipped". These 4 tests however, aren't my created tests for the package. One of my own created tests is a deliberate fail to check if colcon test-result also shows that it failed, which it did not.
I think there might be an issue with my CMakeLists.txt, but I am not certain and do not have a lot of experience with cmake.
See my code here:
driverobot.hpp##
#ifndef DRIVEROBOT_HPP
#define DRIVEROBOT_HPP
#include <memory>
#include "rclcpp/rclcpp.hpp"
#include "std_msgs/msg/float32.hpp"
#include "geometry_msgs/msg/twist.hpp"
using std::placeholders::_1;
class DriveRobot : public rclcpp::Node
public:
  DriveRobot();
  float ParseMsg(float msg);
private:
  void topic_callback(const std_msgs::msg::Float32::SharedPtr msg);
  rclcpp::Subscription<std_msgs::msg::Float32>::SharedPtr subscription_;
  rclcpp::Publisher<geometry_msgs::msg::Twist>::SharedPtr publisher_;
#endif //DRIVEROBOT_HPP
driverobot_test.cpp
#include "driverobot.hpp"
#include "gtest/gtest.h"
TEST(DriveRobot_test, parse_msg_test)
    DriveRobot robot;
    EXPECT_FLOAT_EQ(0.22, robot.ParseMsg(12));
    EXPECT_FLOAT_EQ(-0.22, robot.ParseMsg(-1));
    EXPECT_FLOAT_EQ(0.14, robot.ParseMsg(0.14));
    EXPECT_EQ(0, robot.ParseMsg(0));
TEST(Driverobot_test, deliberate_fail)
    DriveRobot robot;
    EXPECT_EQ(0, robot.ParseMsg(1));
    rclcpp::init(argc, argv);
    ::testing::InitGoogleTest(&argc, argv);
    return RUN_ALL_TESTS();
CMakeLists.txt
cmake_minimum_required(VERSION 3.16.3)
project(driverobot)
set(THIS_PACKAGE_INCLUDE_DEPENDS
    rclcpp
    std_msgs
    geometry_msgs
foreach(Dependency IN ITEMS ${THIS_PACKAGE_INCLUDE_DEPENDS})
  find_package(${Dependency} REQUIRED)
endforeach()
if(BUILD_TESTING)
  find_package(ament_cmake_gtest REQUIRED)
  find_package(ament_lint_auto REQUIRED)
  # the following lines skip linters
  set(ament_cmake_cppcheck_FOUND TRUE)
  set(ament_cmake_copyright_FOUND TRUE)
  set(ament_cmake_cpplint_FOUND TRUE)
  set(ament_cmake_flake8_FOUND TRUE)
  set(ament_cmake_uncrustify_FOUND TRUE)
  ament_lint_auto_find_test_dependencies()
  # Run all lint tests in package.xml except those listed above
  ament_add_gtest_executable(driverobot_test
    test/driverobot_test.cpp
  target_include_directories(driverobot_test
  PUBLIC
    $<BUILD_INTERFACE:${CMAKE_CURRENT_SOURCE_DIR}/include>
    $<INSTALL_INTERFACE:include>)
  target_sources(${PROJECT_NAME}_test PRIVATE src/driverobot.cpp)
  # add_executable(${PROJECT_NAME}_test ${target_sources})# make the tests an executable so you can manually run them if needed
  ament_target_dependencies(${PROJECT_NAME}_test ${THIS_PACKAGE_INCLUDE_DEPENDS})
  install(TARGETS
      DESTINATION test/${PROJECT_NAME})
endif()
ament_export_dependencies(${THIS_PACKAGE_INCLUDE_DEPENDS})
ament_package()
Originally posted by mrbh on ROS Answers with karma: 21 on 2022-04-22
ament_add_gtest_executable only calls add_executable() and links the target against the gtest libraries. It does not register the executable as a test. (Check https://github.com/ament/ament_cmake/blob/2bf27ce5ad01af340e1f4efd44232c1067d0dbda/ament_cmake_gtest/cmake/ament_add_gtest_executable.cmake#L16-L19)
What you want instead is ament_add_gtest. This macro calls add_executable(), links the target against the gtest libraries, and registers the executable as a test. (Check https://github.com/ament/ament_cmake/blob/2bf27ce5ad01af340e1f4efd44232c1067d0dbda/ament_cmake_gtest/cmake/ament_add_gtest.cmake#L16-L19)
For completeness, if you were using ament_add_gtest_executable, you would have to supplement it with a call to ament_add_gtest_test, which registers an executable created with ament_add_gtest_executable as a test. (Check https://github.com/ament/ament_cmake/blob/2bf27ce5ad01af340e1f4efd44232c1067d0dbda/ament_cmake_gtest/cmake/ament_add_gtest_test.cmake#L16-L19)
So you either do:
ament_add_gtest(driverobot_test
or
ament_add_gtest_test(driverobot_test)
Originally posted by aprotyas with karma: 456 on 2022-04-22
Post score: 4
Comment by psammut on 2022-06-28:
I just lost 2 hours of my life because of this. How did you learn about this?
Comment by aprotyas on 2022-06-28:
I want to say "I was there when it was written", but really I also wasted a couple of hours and was frustrated enough to go through the ament_cmake code haha!
