Is it possible to put a client node inside a server node when making service?
Iam trying to make a Service and as far as I know, all the functions are stored in the server node and inside the client node is where the parameters or arguments you want for the server. What Im trying to make is a service that will spawn turtle n times. The code compiles flawlessly also gives me the response when using rosservice command. Problem is I cant spawn any turtle, (turtlesim_spawn_client.call(srv)) always returns to false. Please help
 #include "ros/ros.h"
 #include "srv_turtlesim/spawn_turtle.h"
 #include "turtlesim/Spawn.h"
 ros::ServiceClient turtlesim_spawn_client;
 class spawn_turtle_class
public:
spawn_turtle_class(ros::NodeHandle& nh)
    turtlesim_spawn_client = nh.serviceClient<turtlesim::Spawn>("turtlesim_spawn");
bool spawn_callback(srv_turtlesim::spawn_turtle::Request &req,
                    srv_turtlesim::spawn_turtle::Response &res)
    bool not_spawn=false;
    turtlesim::Spawn srv;
    ROS_INFO("request: n=%d", (int)req.num_turtle);
    for (int i = 0; req.num_turtle > i; i++)
        srv.request.x = random() % 12;
        srv.request.y = random() % 12;
        srv.request.theta = random() % 360;
        if (turtlesim_spawn_client.call(srv))
            ROS_INFO("response: You got turt");
        else
            ROS_INFO("response: No turt :(");
            not_spawn = true;
    if (not_spawn)
        res.status = "Incomplete";
    else
        res.status = "Done";
    return true;
int main (int argc, char**argv)
ros::init(argc,argv, "spawn_node");
ros::NodeHandle nh;
spawn_turtle_class spawn2(nh);
ros::ServiceServer service = nh.advertiseService("spawn_turtle_srv", &spawn_turtle_class::spawn_callback, &spawn2);
ros::spin();
return 0;
Originally posted by naihart on ROS Answers with karma: 30 on 2022-03-30
Comment by ljaniec on 2022-03-30:
Can you prepare a MWE (Minimal Working Example) of your project with these node and service (or at least your attempts)? Then we can try to help easier :)
Comment by naihart on 2022-03-31:
    bool spawn_turtle(srv_turtlesim::spawn_turtle::Request &req,
        for (int i = 0; req.num_turtle > i; i++){
      //Im trying to call turtlesim/Spawn service client here
            if (spawn_client.call(srv)) {
               res.status= "You got turt";
            else{
               res.status= "No turt :(";
        return true;
    ros::init(argc, argv, "spawn_turtle_service");
    ros::NodeHandle nh;
    ros::ServiceServer service = nh.advertiseService("spawn_turtle2", spawn_turtle);
    ros::ServiceClient spawn_client = nh.serviceClient<turtlesim::Spawn>("spawn");
    ros::spin();
From that comment on my callback, I want to call the turtlesim/Spawn service client but the creation of the client is inside the main function making my request for turtlesim/Spawn undefined
Comment by ljaniec on 2022-03-31:
Can you add this code in the question? Formatting will be better
Im sorry for that, Im new with this ROS and with this forum.
No problem, you will find out everything. BTW there is no ; after the turtlesim::Spawn srv, what kind of error does this show you? Can you copy & paste the entire compile errror from the terminal to the question?
Hi I finally managed to make a decent code than the previous code. It compiles and gives me the response. One problem tho is that turtlesim_spawn_client.call(srv) is not working. it always returns to false. I edited the question already. the separated lines of code are where I got problem.
This is stupid. The only problem with the code is the line
I only need to change the name "turtlesim_spawn" to "spawn". Iam new at ROS and I thought that this name can be change for easy reading. Lesson learned
Originally posted by naihart with karma: 30 on 2022-04-05
Comment by ljaniec on 2022-04-05:
Well, it was right there in the mentioned example below (Listing 8.1, lines 12-16). It's good that you found it yourself.
