Hi! Newbie here. I was trying to run gmapping on our own model but I can't seem to solve this problem in rviz, it says no map received. My global fixed frame is odom and map is subscribed to /map topic. I am trying to generate a map. I am using Ubuntu 20.04 and ROS noetic for this. My tf frames are
world->base_footprint->based_stabelized->base_link->laser
map->odom
Can someone help me with this one? Is there any way I can modify the tf frames?
Originally posted by mgrallos on ROS Answers with karma: 11 on 2022-03-20
Hey, Your tf should be map->odom->base_footprint->.... Also, your global fixed frame will be map.
Originally posted by charithreddy101 with karma: 11 on 2022-03-21
Comment by mgrallos on 2022-03-21:
Hi I figure that I need to change the tf tree as well. How do I exactly do that?
Comment by charithreddy101 on 2022-03-22:
Please give more information regarding your problem while asking the question so that people can give you an exact solution. Include if you are working on a simulated model by using any gazebo plugins, controllers or making a real robot.
Coming to the tf, if you are using the gazebo plugins or calculation odom data using math, you must have declared your odom frame and base_footprint in the plugin itself. It will directly create a transform between /odom and /base_footprint
Else, you can also create a static transform as @nigeno said.
First, you need to make sure that you have /map published.
To check it, run:
rostopic list
see that you have /map in the list.
To check /map message published, run:
rostopic echo /map
Next, if you have the /map published but you don't see it in Rviz, then you should have a problem in Rviz setup. If you found that /map is not published, check your gmapping, it might be that you don't have proper /tf or other reasons.
Hi, thanks. I have map in my rostopic list. According to my research, I need to modify TF tree but I really have no idea how to do. I only knew how to set odom_fram and base_frame and it create a separate TF tree
Comment by nigeno on 2022-03-21:
it's not clear why you would need the transforms if you have /map topic. But anyways..
What's your relation between base_link and odom frames?
The reason why I'm asking is you need to provide two transformations to gmapping to work: base_link -> laser; odom -> base_link
If you have them plus /laser topic then gmapping will give you map -> odom transformation plus /map.
The other transforms shouldn't be required for gmapping to work.
To test it out use the following static transforms:
rosrun tf2_ros static_transform_publisher 0 0 0 0 0 0 odom base_link
rosrun tf2_ros static_transform_publisher 0 0 0 0 0 0 base_link laser
If this works, then you know which transforms you need and you can provide dynamic ones.
Comment by mgrallos on 2022-05-04:
Hi thank you for this.
