I have a python package and want to copy a folder "models", that have subfolders, to installation path. In setup.py file I have tried to do that including the following lines of code:
    data_files=[
    ('share/ament_index/resource_index/packages',
        ['resource/' + package_name]),
    ('share/' + package_name, ['package.xml']),
    (os.path.join('share', package_name, 'models'), glob('models/**', recursive=True)),]
But when I build the package I get this error: "error: can't copy 'models/': doesn't exist or not a regular file".
Please, could someone tell me how I can do it?
Thank you very much in advance for your help.
Originally posted by joseecm on ROS Answers with karma: 130 on 2022-03-09
Comment by scottie on 2023-05-18:
Are you trying to package this code with a wheel or debian? If you're using debian, you can use the install(DIRECTORY) command in CMakeLists.txt to copy folders.
Comment by joseecm on 2023-05-27:
Hello @scotie, thanks for your answer. My package is a python package, so It doesn't have a CMakeLists.txt.
I have finally managed to solve the problem by creating a function that reads the directory tree and includes the information in DATA_FILES. Here is an example in case someone finds it useful. In the code the "models/" and "worlds/" folders contain subfolders. If anyone knows a simpler way to do this I would be very grateful if you would share the information.
import os
from glob import glob
from setuptools import setup
package_name = 'myrobot_gazebo'
data_files=[
def package_files(data_files, directory_list):
    paths_dict = {}
    for directory in directory_list:
        for (path, directories, filenames) in os.walk(directory):
            for filename in filenames:
                file_path = os.path.join(path, filename)
                install_path = os.path.join('share', package_name, path)
                if install_path in paths_dict.keys():
                    paths_dict[install_path].append(file_path)
                else:
                    paths_dict[install_path] = [file_path]
    for key in paths_dict.keys():
        data_files.append((key, paths_dict[key]))
    return data_files
setup(
    name=package_name,
    version='0.0.0',
    packages=[package_name],
    data_files=package_files(data_files, ['models/', 'launch/', 'worlds/']),
    install_requires=['setuptools'],
    zip_safe=True,
    maintainer='ros',
    maintainer_email='[email protected]',
    description='TODO: Package description',
    license='TODO: License declaration',
    tests_require=['pytest'],
    entry_points={
        'console_scripts': [
Best regards.
Originally posted by joseecm with karma: 130 on 2022-03-11
Post score: 4
For anyone who stumbles upon this in 2023. You can also use the following list comprehension to generate the tuples:
[(os.path.join('share', package_name, os.path.split(path)[0]), [path]) for path in glob.glob('models/**', recursive=True)]
Then just concatinate it with the data files list.
Best regards.
