I'm trying to solve this puzzle. It seems to be simple but it doesn't work.
So, the OdomNode is subscribed to the original LaserScan message on /sick_lrs_36x1/scan topic. It receives the message and call LaserScan publisher to publish the message on /scan topic. A customized message is published with a new frame_id and with now timestamp.
The original scan message is getting played using the bag tool.
Running
ros2 topic echo /sick_lrs_36x1/scan
seems to give exact message as
ros2 topic echo /scan message
Interestingly, I can observe the /sick_lrs_36x1/scan in rviz, but cannot see the customized message.
Below is my code:
class OdomNode : public rclcpp::Node
public:
    OdomNode() : Node("odom")
        scan_ = this->create_subscription<sensor_msgs::msg::LaserScan>("/sick_lrs_36x1/scan", rclcpp::SensorDataQoS(),
                                    std::bind(&OdomNode::callbackPose, this, std::placeholders::_1));
        publisher_ = this->create_publisher<sensor_msgs::msg::LaserScan>("scan", rclcpp::SensorDataQoS());
private:
    void callbackPose(const sensor_msgs::msg::LaserScan::SharedPtr msg)
        now = this->get_clock()->now();
        sensor_msgs::msg::LaserScan laser;
        laser.header.frame_id = "cloud";
        laser.header.stamp = now;
        laser.angle_min = msg->angle_min;
        laser.angle_max = msg->angle_max;
        laser.angle_increment = msg->angle_increment;
        laser.scan_time = msg->scan_time;
        laser.time_increment = msg->time_increment;
        laser.range_min = msg->range_min;
        laser.range_max = msg->range_max;
        laser.ranges = msg->ranges;
        publisher_->publish(laser);
    rclcpp::Time now;
    rclcpp::Subscription<sensor_msgs::msg::LaserScan>::SharedPtr scan_;
    rclcpp::Publisher<sensor_msgs::msg::LaserScan>::SharedPtr publisher_;
    rclcpp::TimerBase::SharedPtr transform_timer_;
    rclcpp::init(argc, argv);
    auto node = std::make_shared<OdomNode>();
    rclcpp::spin(node);
    rclcpp::shutdown();
    return 0;
Originally posted by nigeno on ROS Answers with karma: 76 on 2022-03-04
I figured. You need to set the Reliability Policy of the LaserScan topic in Rviz to Best Effort or System Default
Originally posted by nigeno with karma: 76 on 2022-03-07
