HI All,
I am a bit new to this. I have a robot with the scanner (RPLIDAR) located at the center of the the robot base, but it is rotated 90 degrees about axis z . What should I set the qw value for my static transform, its it needed? In the example I saw it set to 1 ? I tried below but it does not reflect the proper 90 degree rotation in rviz.
node pkg="tf2_ros" type="static_transform_publisher" name="link1_broadcaster" args="0 0 0 0 0 1.571 1 base_robot base_laser"
Originally posted by chm007 on ROS Answers with karma: 34 on 2022-03-03
