I trying to access osrf_gear::Order message elements within orderCallback scope. The structure of the message is as following:
string order_id
osrf_gear/Shipment[] shipments
  string shipment_type
  string agv_id
  osrf_gear/Product[] products
    string type
    geometry_msgs/Pose pose
      geometry_msgs/Point position
        float64 x
        float64 y
        float64 z
      geometry_msgs/Quaternion orientation
        float64 x
        float64 y
        float64 z
        float64 w
The orderCallback code is following:
void orderCallback(const osrf_gear::Order::ConstPtr &order){
    if(!empty_vector_check){
        orders.clear();
        empty_vector_check = 1;
    osrf_gear::Shipment order_shipments;
    order_shipments = order->shipments;  // IDE yells that this is an invalid way to assign an osrf_gear::Shipment message type
    ROS_INFO_STREAM("order_id: " << order->order_id);
    ROS_INFO_STREAM("shipment_type: " << order_shipments);
    orders.push_back(*order);
The osrf_gear::Shipment message structure is as following:
string agv_id
  string type
      float64 x
      float64 y
      float64 z
      float64 x
      float64 y
      float64 z
      float64 w
Error message while building the package:
no known conversion for argument 1 from ‘const _shipments_type {aka const std::vector<osrf_gear::Shipment_<std::allocator<void> >, std::allocator<osrf_gear::Shipment_<std::allocator<void> > > >}’ to ‘const osrf_gear::Shipment_<std::allocator<void> >&’
/opt/ros/melodic/include/osrf_gear/Shipment.h:23:8:
My questions:
  1. What would be the correct syntactical way to access the shipment[] msg type using the osrf_gear::order callback parameter?
  2. I want to access the osrf_gear::Product products vector to know what type of products I have in the shipment.
Thank you in advance!
Originally posted by abhijelly on ROS Answers with karma: 18 on 2022-02-16
shipments in the order message type is a vector of type osrf_gear::Shipment. This change solved the IDE from yelling.
Have a nice day!
Originally posted by abhijelly with karma: 18 on 2022-02-16
Comment by gvdhoorn on 2022-02-17:\
Have a nice day!
we can only have a nice day if you would tell us what you did to resolve your question.
Comment by abhijelly on 2022-02-18:
@gvdhoorn done! hope it helps everyone have a nice day
