Hi, I am using the nodelet obstacle_detection from rtabmap to output a pointcloud that contains the obstacles to avoid.
I launch the obstacles_detection nodelet using:
   <launch>
   <node pkg="nodelet" type="nodelet" name="obstacles_detection" args="load rtabmap_ros/obstacles_detection stereo_nodelet">
      <remap from="cloud" to="/obstacles_cloud"/>
      <remap from="obstacles" to="/pointCloud_obstacles"/>
      <param name="frame_id" type="string" value="base_link"/>
      <param name="map_frame_id" type="string" value="map"/>
      <param name="min_cluster_size" type="int" value="5"/>
      <param name="cluster_radius"       type="double" value="0.1"/>
      <param name="max_obstacles_height" type="double" value="0.5"/>
   </node>
   </launch>
The problem is that the node doesn't subscribe to the obstacles_cloud topic and don't publish the pointCloud_obstacle topic.
The obstacle_detection node launches without errors, moreover the obstacles_cloud topic is correctly published from the pointcloud_xyz node.
To launch the pointcloud_xyz node I use:
   <node pkg="nodelet" type="nodelet" name="points_xyz" args="standalone rtabmap_ros/point_cloud_xyz">
   <remap from="depth/image"         to="/zed2/depth/depth_registered"/>
   <remap from="depth/camera_info"   to="/zed2/depth/camera_info"/>
   <remap from="cloud"               to="/obstacles_cloud" />
   <param name="decimation"  type="double" value="4"/>
   <param name="voxel_size"  type="double" value="0.05"/>
   <param name="approx_sync" type="bool" value="false"/>
</node>
I checked the behaviour of the node points_xyz using rostopic echo /obstacles_cloud and the node works correctly, it sends the correct type of messages (Sensor_msgs/Pointcloud2) on the correct topic at a rate of about 11Hz and they are not empty.
The output I get using rosnode info /obstacles_detection is
Node [/obstacles_detection]
Publications:
 * /rosout [rosgraph_msgs/Log]
Subscriptions:
 * /clock [rosgraph_msgs/Clock]
Services:
 * /obstacles_detection/get_loggers
 * /obstacles_detection/set_logger_level
contacting node http://alessio-pc:36503/ ...
Pid: 22655
Connections:
 * topic: /rosout
    * to: /rosout
    * direction: outbound (47561 - 127.0.0.1:36618) [12]
    * transport: TCPROS
 * topic: /clock
    * to: /gazebo (http://alessio-pc:34549/)
    * direction: inbound (45134 - alessio-pc:44717) [13]
    * transport: TCPROS
And this confirms that the node is not subscribed to any topic.
Originally posted by AlessioParmeggiani on ROS Answers with karma: 165 on 2022-01-29
Comment by matlabbe on 2022-01-29:
You are loading the first nodelet in nodelets manager stereo_nodelet, does it exist? Otherwise, try launching like the second nodelet as a standalone.
Comment by AlessioParmeggiani on 2022-01-30:
Hi @matlabbe, thank you for answering!
I think it should exist because I am following the official tutorial proposed in the documentation of Rtabmap and it uses the same code: http://wiki.ros.org/rtabmap_ros/Tutorials/StereoOutdoorNavigation#Local_costmap.
I'll check that nodelet then, thank you for your suggestion!
Comment by matlabbe on 2022-01-30:
I updated the example in the wiki with the nodelet manager, as seen in the referred launch file here https://github.com/introlab/rtabmap_ros/blob/62b1058218ebdaa41a8c17b27eeccf7cf2d5e0ae/launch/azimut3/az3_mapping_robot_stereo_nav.launch#L69
Comment by AlessioParmeggiani on 2022-01-31:
Thank you! I added to the launch file:
 <node pkg="nodelet" type="nodelet" name="stereo_nodelet"  args="manager"/>
Now I am able to launch the node and it correctly subscribe to the topics :)
But I ecnountered another problem, I get a new error from the obstacles_detection nodelet:
Lookup would require extrapolation -0.120000000s into the future.  Requested time 1027.127000000 but the latest data is at time 1027.007000000, when looking up transform from frame [base_link] to frame [map]
I'll look into that. EDIT: Question with solution to this new problem
The problem has been solved by adding to the launch file:
as suggested by user matlabbe above. See comments to question for more details
Originally posted by AlessioParmeggiani with karma: 165 on 2022-02-08
