I have a problem to include the package "image_transport" correctly. This is my CMakeList:
cmake_minimum_required(VERSION 3.5) project(camera_pkg)
Default to C++14
if(NOT CMAKE_CXX_STANDARD) set(CMAKE_CXX_STANDARD 14) endif()
if(CMAKE_COMPILER_IS_GNUCXX OR CMAKE_CXX_COMPILER_ID MATCHES "Clang") add_compile_options(-Wall -Wextra -Wpedantic) endif()
find_package(ament_cmake REQUIRED COMPONENTS cv_bridge image_transport rclcpp sensor_msgs std_msgs )
find_package(ament_cmake REQUIRED) find_package(rclcpp REQUIRED) find_package(std_msgs REQUIRED) find_package(OpenCV REQUIRED) find_package(sensor_msgs REQUIRED) find_package(cv_bridge REQUIRED)
add_executable(camera camera_pkg.cpp) ament_target_dependencies(camera rclcpp std_msgs OpenCV cv_bridge)
install(TARGETS camera DESTINATION lib/${PROJECT_NAME} )
include_directories( ${OPENCV_INCLUDE_DIRS} ${ament_cmake_INCLUDE_DIRS} )
target_link_libraries(camera ${OPENCV_LIBRARIES})
target_link_libraries(camera ${OPENCV_LIBRARIES} ${ament_cmake_LIBRARIES})
target_link_libraries(camera ${rclcpp_LIBRARIES})
target_link_libraries(camera ${rclcpp_LIBRARIES} ${ament_cmake_LIBRARIES})
target_link_libraries(camera ${sensor_msgs_LIBRARIES})
target_link_libraries(camera ${sensor_msgs_LIBRARIES} ${ament_cmake_LIBRARIES})
target_link_libraries(camera PUBLIC ${EXTRA_LIBS})
if(BUILD_TESTING) find_package(ament_lint_auto REQUIRED) ament_lint_auto_find_test_dependencies() endif()
ament_package()
My package.xml looks like this:
camera_pkg 0.13.0 Examples of minimal publisher nodes Shane Loretz Aditya Pande Apache License 2.0 Mikael Arguedas Morgan Quigley Jacob Perron
<buildtool_depend>ament_cmake</buildtool_depend>
<build_depend>rclcpp</build_depend> <build_depend>std_msgs</build_depend> <build_depend>sensor_msgs</build_depend> <build_depend>OpenCV2</build_depend> <build_depend>image_transport</build_depend> <build_depend>cv_bridge</build_depend>
<exec_depend>rclcpp</exec_depend> <exec_depend>std_msgs</exec_depend> <exec_depend>sensor_msgs</exec_depend> <exec_depend>OpenCV2</exec_depend> <exec_depend>image_transport</exec_depend> <exec_depend>cv_bridge</exec_depend>
<test_depend>ament_lint_auto</test_depend> <test_depend>ament_lint_common</test_depend>
ament_cmake
When I compile my code with the "colcon build" command I get this error:
undefined reference to `image_transport::create_publisher(rclcpp::Node*, std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&, rmw_qos_profile_t)'
undefined reference to `image_transport::Publisher::publish(std::shared_ptr<sensor_msgs::msg::Image_std::allocator<void > const> const&) const'
Can anyone help me what else needs to be added in the CMakeList and in the package.xml ?
Originally posted by SJeya on ROS Answers with karma: 1 on 2022-01-24
You'll need to add a
find_package(image_transport REQUIRED)
and add a
    rclcpp
    sensor_msgs
    image_transport)
Note that it's recommended to use the ament_target_dependencies(...) for ros2 packages vs using target_link_libraries(...)
Originally posted by ChuiV with karma: 1046 on 2022-02-04
Comment by SJeya on 2022-02-05:
I have added these lines. But I get a different error now:
CMake Error at CMakeLists.txt:28 (find_package): By not providing "Findimage_transport.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "image_transport", but CMake did not find one.
Could not find a package configuration file provided by "image_transport" with any of the following names:
image_transportConfig.cmake
image_transport-config.cmake
Add the installation prefix of "image_transport" to CMAKE_PREFIX_PATH or set "image_transport_DIR" to a directory containing one of the above files. If "image_transport" provides a separate development package or SDK, be sure it has been installed.
Do you know where the problem could be ?
Comment by ChuiV on 2022-02-05:
Is the image transport package installed?
