Description
After updating to ubuntu 20.04, I tried to create a new config file using moveit setup assistant. However, position_controllers/JointTrajectoryController was identified in the ROS Control pane selector, but position_controllers/JointPositionController was missing.
My environment
ROS Distro: [noetic]
OS Version: Ubuntu 20.04
Steps to reproduce :
https://ros-planning.github.io/moveit_tutorials/doc/setup_assistant/setup_assistant_tutorial.html
I followed the link above to proceed with the movement setup assistant tutorial.
Expected behaviour :
Select Position_controllers/Joint Position Controller from the ROS Control pane selector.
Actual behaviour :
Position_controllers/JointPositionController does not exist in the option.
image description
Originally posted by sm3304ove on ROS Answers with karma: 11 on 2022-01-22
Comment by gvdhoorn on 2022-01-24:
Cross-posted to ros-planning/moveit#3033 and ros-planning/moveit_tutorials#698.
Please do not cross-post like this.
I believe this is expected, as MoveIt cannot directly use a plain JointPositionController.
It needs a JointTrajectoryController. That's why you only see those in the dropdown.
Originally posted by gvdhoorn with karma: 86574 on 2022-01-23
Comment by sm3304ove on 2022-01-24:
So should I choose JointTrajectoryController? I used to be able to select Position_controllers/JointPositionController in ubuntu 18.04, why is it gone in the noetic version?
This may happen if the position controller package is not installed for some reason.
Try:
sudo apt-get install ros-noetic-position-controllers
I tried the method you suggested, but it says the latest version is already installed.
